1996 Camaro 3.8 Heater Problems - Team Camaro Tech
Heating & Cooling Heating, cooling and air conditioning
Thread Tools Display Modes
Old Feb 2nd, 07, 08:43 AM
pudhead pudhead is offline
Kent
Default 1996 Camaro 3.8 Heater Problems
Hello everyone and it is very nice to be here. Just wondered if anyone else has had this problem and what could be the cause. I have a 96 Camaro 3.8 engine automatic, the engine temperature stays about 160, I have installed a new radiator and 18 lb cap, heater core and 195 degree thermostat. The engine very seldom gets past 160 degrees operating temp and the heater always blows luke warm air, the electric fans are not running at all times and the heater control valve is operating normally. What could be the problem? Any help anyone can give me will be greatly appreciated. I live in North Carolina and some better heat would be nice. Thank-you,, Kent
Old Feb 2nd, 07, 11:48 AM
novaderrik novaderrik is offline
Default Re: 1996 Camaro 3.8 Heater Problems
did you check your new t-stat before putting it in?
sometimes they are bad right out of the box, and they can either stick open or stick closed.
you don't plan sincerity.
you have to make it up on the spot.
wanna hear about 20 years ago when i was too smart to know any better?
Old Feb 3rd, 07, 08:26 AM
kustomwerker kustomwerker is offline
mike
18 lb cap is too much imo for a plastic tank radiator...should be more like 13-15lb...did u get the tstat from napa???i`ve done 3 in my truck before i decided stant is the way to go...also make sure to use the proper coolant, as mixing dex-cool with conventional coolant is a nono..(that derrek is always right on point)
Old Feb 3rd, 07, 12:17 PM
i don't think a 16 pound cap is too much for the plastic expansion tank- the cap i got for my 94 Caprice was a 22lb cap.
Old Feb 3rd, 07, 01:28 PM
mike
just my experience on the cap thing...i dont know about the cap on an expansion tank, but i know that if you overpressurize a plastic radiator, it leaks almost invariably at the seam between the tank and the cores...in addition, i`ve seen alot of dex-cooled vehicles with sludged up heater cores and you can usually backflush them to clean them up...that doesnt sound like your problem, but if the guage is not accurate, and you are at operating temp, maybe so...
Old Feb 3rd, 07, 03:23 PM
Kent
Thanks for all the great suggestions, it has a stant t-stat, that I have taken out and checked in boiling water and it worked fine, it also has dex-cool in the radiator. I have an 18 lb cap,on now but tried a 16 lb a few weeks back it made no difference. Thanks again.
Old Feb 3rd, 07, 03:45 PM
mike
the cap wont stop it from getting warm, but only allow the expanding coolant to go into the overfolw tank...with that said, the more pressure a system will hold, the hotter it can get without boiling...i dont know, man...i`d try another tstat...did you consider the diverter door in the air box???i`ve seen where a mouse built a nest in the air box, and it wouldnt close off to only pass hot air...
Old Feb 4th, 07, 10:13 AM
nancys96z nancys96z is offline
Nancy
Hello there,
I also have a 96, and I freeze all the way to work in the morning. I have checked everything, any help would be greatly appreciated.
thanks
Old Feb 4th, 07, 11:13 AM
mike
well this thread covered just about all of it nancy...if you have something specific to ask, theres a lot of really knowledgable people on this site that will make an attempt to help you...
Old Feb 5th, 07, 01:41 PM
tumper tumper is offline
erik
Does it get hot while sitting still and then cool off while driving? Or does it not get to operating temperatures under any condition? Is there pressure on the upper hose or can you colapse it? If the system will not build pressure it can keep you from having heat and on some gm vehicles keep you from reaching operating temperatures!
  #11
Old Feb 7th, 07, 05:22 PM
Nancy
It does rise when I set at the stop signs and cools off as I drive. I put a new thermastat on. The coolant level is good. I am not sure what else to do. Thanks for all of your help
  #12
Old Feb 7th, 07, 05:43 PM
mike
nancy, when the car`s at op temp, feel the hoses going in and out of the heater core with the blower fan on high...if theres a restriction in the heater core, the in hose will be hot, and the out hose will be cool, but if no restriction, they will be close to the same temp...i`ve noticed that dex-cooled cars seem to plug heater cores more often than the old green stuff...might just need to be backflushed...
  #13
Old Feb 8th, 07, 03:52 PM
Nancy
Thanks I will try that, I will let you know if it worked.
  #14
Old Feb 10th, 07, 03:07 PM
Nancy
I had everything flushed and new put in. It is still luke warm. He said my coolant wasnt very good. Now he is telling me that it could be a head gasket, but it isnt leaking anywhere. So who knows. Thanks for all of the help
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Heating & Cooling      Current Topic: 1996 Camaro 3.8 Heater Problems
Location
Location
First Name
Human Verification
Similar Threads
GM Insiders Tell Us How A Long-Awaited Dream - The New Camaro OverAnxious Fifth Generation 41 Aug 3rd, 06 06:13 PM
Heater Hoses 1st gen 68 camaro 68Camaro/FL Heating & Cooling 3 Jul 22nd, 06 06:18 AM
1996 camaro, will not start? Gr33n Electrical & Wiring 3 May 28th, 06 12:45 PM
2004 SuperCar Reunion Labor Day weekend HawaiianCamaro Team Camaro Cruiz-Ins 1 Aug 25th, 04 09:51 PM
69 camaro heater box BB versus SB jmar Tech 2000 4 Feb 14th, 00 01:14 AM
