4th gen rear axle into a 3rd gen?? - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old Feb 2nd, 07, 08:53 PM
Boosted_SS Boosted_SS is offline
Rich
Default 4th gen rear axle into a 3rd gen??
hey everyone i have a question i was hoping you all could help me with. i am thinking about swapping out my 3rd gen rear end for a 4th gen rear end. will it fit without modifications? i have an 88 camaro with rear drums and i was hoping to get the rear disc brakes and still have parts easy to find. also i have done some work to the stock rear end (GM 3.73 gears and an eaton pro posi unit) will the ring and pinion and the posi bolt into the unit from the 4th gen? i know the axles are very similar. will i have to get a new brake master cylinder? any thoughts would be extremely helpful. thanks guys!
Rich
rbowers403@zoominternet.net
Old Feb 2nd, 07, 08:57 PM
WildBillyT WildBillyT is offline
Bill
Default Re: 4th gen rear axle into a 3rd gen??
It will stick out, I think the 4th gen rears are 1" longer.
Old Feb 2nd, 07, 09:01 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Scott
If you have a 10-bolt and the 4th gen rear is a 10-bolt, the brake package should be able to transfer over.
Scott from NJ. Stay thirsty, my friends
Vent Windows Forever! ... My junk ... NastyZ28 ... NJ Camaros & Firebirds
Feather-light suspension, Konis just couldn't hold
I'm so glad I took a look inside your showroom doors
TC Member #13
Old Feb 2nd, 07, 09:06 PM
Rich
yes it's the stock 10 bolt. believe it has the 8.5" ring gear and 26 spline axles. basically i want to buy one from the junk yard and take my gears and posi out of my axle and transplant them into the axle from the junk yard and bolt it into my car and hook up the disc brakes.
Old Feb 2nd, 07, 09:17 PM
Scott
3rd & 4th gen rears are not 8.5"
Why are you looking to do it the hard way? Just pull the axles, unbolt the drum backing plates, bolt on the disc brackets, reinstall the axels. You just have to get the disc brackets off a 10 bolt rear if you have a 10 bolt rear, the flange is the same (also same on 8.5 a bolt, 12 bolt) but not the 9-bolt 3rd/4th gen rear.
TC Member #13
Old Feb 2nd, 07, 09:31 PM
Rich
OOOO OK! so if i get the 10 bolt axel from a 4th gen the brake package will bolt right onto the 10 bolt from the 3rd gen?that would be sweeeeeeet!!!! it would make my life ALOT easier! LOL what size is the ring gear on the 10 bolts? sorry it's been about 7 years since i did the rear end and i forget lol
also will i have to change the brake booter, master, or the proportioning valve?
Old Feb 2nd, 07, 09:33 PM
Scott
~7.5
TC Member #13
Old Feb 2nd, 07, 09:35 PM
Rich
so to make sure this is correct the brakes just unbolt and are interchangeable from the 3rd gen drum and 4th gen disc?
Old Feb 2nd, 07, 09:37 PM
Scott
Get a 3rd gen disc/disc master & prop valve.
TC Member #13
Old Feb 2nd, 07, 09:38 PM
Scott
Also, search around www.thirdgen.org
http://www.thirdgen.org/techboard/brake-board/
TC Member #13
  #11
Old Feb 2nd, 07, 09:50 PM
Rich
you sir are the effin man!!!
  #12
Old Feb 3rd, 07, 12:01 AM
novaderrik novaderrik is offline
i could be wrong, but i think all the drum brake 3rd gen Camaros with drum brakes used the same axle flange as the "G" bodies- Monte SS, Regal, etc. this is an oddball flange that is unlike any other rear axle- but i have read of people using the disc brake bracket as a template to drill the proper mounting holes for the disc brakes. the only 3rd gens with factory rear disc brakes had the oddball Borg Warner rear axle with a totally different axle flange, and not the 7.5.
all the 4th gen rears had the standard 10/12 bolt axle flange, and got upgraded to a slightly larger 7 5/8" ring gear.
also, i think they went from 26 spline axles to 28 spline with the switch to the 4th gen in 93.
so, if it actually works, get the rear disc stuff from a newer Camaro- or an S10 Extreme- and modify the axle flange to accept it.
you don't plan sincerity.
you have to make it up on the spot.
wanna hear about 20 years ago when i was too smart to know any better?
  #13
Old Feb 3rd, 07, 03:08 PM
Rich
actually upon further research it seems as though 87+ is 7 5/8 and 28 spline axles so they should be interchangeable. i hope! LOL i'm going to try and talk to the mechanic who does the rear ends at the local dealership to confirm this but the i looked up the eaton posi unit for an 88 camaro with a 10 bolt and a 95 camaro with a 10 bolt they were the same part number so i would assume they are interchangeable. i liked the idea of just switching out the brakes and leaving the original axle. has anyone actually tried this? if not the 3rd and 4th gen axles are interchangeable with no modifications correct?
  #14
Old Feb 3rd, 07, 07:28 PM
Rich
is it possible to completely unbolt the brake assembly (backing plate, caliper mounting bracket, calipers, rotors, etc) from the 4th gen rear end and bolt it directly onto a 3rd gen rear after removing the entire drum assembly? will the mounting holes line up? or if that isn't possible to do is it possible to do it with the disc brake assembly from a 91-92 camaro which i hear are the same? has anyone done this?
  #15
Old Feb 3rd, 07, 08:27 PM
blue89bird's Avatar
blue89bird blue89bird is online now
Jason
4th gen rear ends are 1.5" longer on each side
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: 4th gen rear axle into a 3rd gen??
Location
Location
First Name
Human Verification
Similar Threads
3rd Gen Rear Disc Brakes InsaneCamaroDriver Brakes, Suspension & Steering 0 Jul 16th, 06 03:20 PM
thinking about switching from 1st gen to 3rd gen tmannet Bench Racing 37 Nov 14th, 05 09:26 PM
1969 Z28 Rear Axle Question 3055NRM Tag Team 6 Jul 9th, 05 11:44 AM
Has anyone used a 3rd gen console in a 1st gen? MStennes Interiors 1 Apr 17th, 05 06:25 PM
Rear end noise in axle jlighthart Engine 2 Jan 9th, 03 03:28 PM
