Pro Touring Todays performance with classic style
Old Feb 3rd, 07, 05:19 PM
sicdog sicdog is offline
Tech Team
Default installing front coilovers with tube a-arms
I am trying to install qa1 coilovers with heidts a-arms i need to know if the coilover bolts on top of the lower arm or below ? if it bolts below how do you remove the cross shaft so you can drop it threw the hole. 68 vert help me!
Old Feb 3rd, 07, 09:48 PM
davidpozzi davidpozzi is offline
David Pozzi
Default Re: installing front coilovers with tube a-arms
It bolts to the top of the A arm. Break the lower balljoint loose, lower the arm and install the shock, then replace the arm. If you ever have to replace the shock, you have to drop the arm again. Aren't coilovers fun?
David
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
Old Feb 4th, 07, 05:19 AM
Tech Team
Thanks Dave great web site i have saved it to favorites
Similar Threads
Installing front shocks??? (weight transfer??) Procharged69 Tech 2000 5 Sep 17th, 06 08:28 PM
Door adjustment jsouthco68camaro Body Shop 9 Mar 7th, 05 06:46 AM
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 02:45 AM
Hood adjustments!! Handy69Z Body Shop 2 Mar 13th, 03 05:14 AM
Hanging Doors ? wesley58_do Body Shop 6 Jan 30th, 02 12:23 PM
