Local Z/28 numbers - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Feb 7th, 07, 04:50 AM
drdave69 drdave69 is offline
Default Local Z/28 numbers
I was visiting with a friend at his body shop and he has a 1969 Z/28-RS there doing a little work to it. It needs a restoration but I don't think the owner is ready for that yet (I haven't met him). I copied down some of the important data because I was curious to see if it is listed in the database and because it does have a DZ coded engine but not the original (to see if the original car is around). I know how all of this decodes except for the axle code. Here is the basic data.
VIN - 124379N614471
Cowl tag -
ST69 12437NOR279713 BDY
TR 711 71 71 PNT
03B X33
Engine pad - 19N520236 (is this car around?) VI009DZ
Trans - 19N614474 P9B26B
Rear axle - BL1226G2
Dave, member number 7704
2000 Dodge Viper GTS
Old Feb 7th, 07, 12:30 PM
Kurt S Kurt S is offline
Default Re: Local Z/28 numbers
Date looks right on the motor, but nothing on either VIN.
Trans is original but axle isn't (Dec 26, 3.07 open).
If you get a chance, I'd be interested in a pic of the engine pad and the trans stamps. If not, no biggie.
Thanks!
Kurt S.
CRG - www.camaros.org
Old Feb 7th, 07, 12:46 PM
I may have written something down wrong for the VIN or the trans stamp, I just noticed that they are different in my first post. So, it isn't possible that the rear axle is original? I know 3 months is a long stretch but why replace the original with this one (3:07 open)? Was the 3:07 offered as an option for the Z?
I don't know if I'll have the opportunity to get photos of the stamps but I can try. The engine pad had a lot of paint on it.
Old Feb 7th, 07, 01:09 PM
On the pics, if it's a problem, don't sweat it.
Highly unlikely a Z got a 3.07. And almost no chance of 3 months in that time of 69. They were cranking them out at that time.
Kurt S.
Similar Threads
Have got some WIERD 68 Camaro SS numbers...Need help please. z/27 camaro Tag Team 13 Jul 15th, 10 10:34 PM
427 numbers 67-427 Tag Team 2 Jan 12th, 09 06:27 PM
Help with Z/28? cowl tag code and VIN Kent H Tag Team 3 Oct 23rd, 06 09:05 PM
BBC Pro-Comp Heads/Flow Numbers GOSFAST Performance 5 Jun 29th, 06 05:32 PM
Do these numbers look OK? drdave69 Tag Team 0 May 2nd, 03 09:35 AM
