Can i put a deluxe interior in my 68 if it came with a standard interior? - Team Camaro Tech
Body Shop Paint & Body Forum
Old Apr 20th, 00, 04:29 AM
runninhorn runninhorn is offline
Talking
Ill be doing the interior in a little while and wanted to know if i could order the Deluxe interior package instead of the standard. Will it be a direct bolt in so to say? Just wondering if there would be any snags converting.....
Old Apr 20th, 00, 08:03 AM
Chris Edwards Chris Edwards is offline
Red face
not sure, I have a 67 R/S with deluxe interior (although at the moment it does not look so deluxe) but it is different, be prepared to spend some serious $$$, there are a ton of stupid things like sail panel lighting, (there is no main dome light) and deluxe usually had a center console with the rear ashtray light too. the back panels had ashtrays in them too (do they all?) and the rear area where the package tray is has different trim, there is also different trim like window roll down things, door handles are different, (the arm rests are incorporated into deluxe interior sets) and deluxe interior door panels have carpet onthe bottom of them, seatbelts are different. and the headliner is different too, (hence no cut out for the dome light. ) but I think most headliners require you to "cut it yo dang self" anyway.. If theres somthing I am missing or messed up on , I am sure another team member will jump in ...
Chris's 67 RS can be seen at http://www.geocities.com/macphreak4evr/index.html
JOIN THE CAMARO NET WEBRING! www.geocities.com/macphreak4evr/webring/webringjoin.htm !!!
[This message has been edited by Chris Edwards (edited 04-20-2000).]
Old Apr 20th, 00, 08:18 AM
DjD's Avatar
DjD DjD is offline
Dennis
Post
Chris has touched on some very good points! I know in a '69 the window regulators are different. You would never get the window cranks on with dlx door panels and std regulators...
It can be done but there is a lot of research to do first!
...Dennis
Topless'69
rsss.fun@gte.net
Old Apr 20th, 00, 09:32 AM
cardude cardude is offline
Post
I looked into doing the very same thing, and read once where the bottom seat cushions also are different in the deluxe due to the door panels extending further into the interior than the standard panels. I believe it was Classics book or NPD's that has this information.
67 Camaro LS6 454/TH400/12bolt 3.73
Old Apr 20th, 00, 12:57 PM
Baby68RS Baby68RS is offline
Chris
Post
Be prepared to spend about a thousand bucks just on material from "Ricks First Gen", They have full kits. I would imagine there is solid hardware you would need to buy as well. I know Im eyeing the project myself.
www.geocities.com/macgse/68CamaroRS.html
Old Apr 20th, 00, 01:23 PM
Post
so is it possible or should i just go back with the standard?
HELP! i ordered the Weatherstripping for the deluxe interior and if i cant do the deluxe i need to change the order...thanks again
Old Apr 20th, 00, 02:48 PM
stevo camaro's Avatar
stevo camaro stevo camaro is offline
Post
One more thing I can think of is the bracket on door panel. Mine is 67, but there is a different bracket to bolt deluxe panel by inside door handle. Not sure if thats even available. The seat foam IS different for deluxe seats. The pad is a little bit different in shape, thicker. So deluxe skins on standard seat foam would never tighten up so to speak. My SS 396 car had standard, it needs to be redone completely, I'm leaving it that way. Is weather stripping different between standard & deluxe on 68's??
Steve http://www.geocities.com/stevocamaro/
[This message has been edited by stevo camaro (edited 04-20-2000).]
Old Apr 20th, 00, 04:17 PM
Black69 Black69 is offline
Dave
Post
You might be better off just to change the covers on your seats to something like the houndstooth rather than just plain vinyl. It adds to the interior just enough to change the looks.
Old Apr 20th, 00, 05:59 PM
molaker molaker is offline
Post
I faced this question a couple of months ago and it can be done but it will cost lots of $ I decided to go back with the std but, I did go with the deluxe w/strip with the chrome mldgs I don't have it on yet but it should work ok.
Old Apr 21st, 00, 09:23 AM
john68conv john68conv is offline
Post
The back seat is also smaller because the deluxe has rear arm rests. A convertible has the same back seat in the standard and deluxe but if you have a coupe, you will have to change the seat and add arm rests.
Old Apr 21st, 00, 04:27 PM
Post
Wow john, I didn't know the back seat widths were different between standard & deluxe. But It does make sense because panels are wider on deluxe. And to think I have both types, and it took a fellow from grand rapids to make me see it. I learn something new everyday about these cars.
Old Apr 21st, 00, 11:02 PM
Lonnie67 Lonnie67 is offline
Post
My 67 has factory deluxe, but the guy before me installed standard door panels. So, I'm sure you can go the other way too. If you want it to look factory, its probably not worth the cost. There is also the stainless seat belt buckels, and the headliner trim above the windows is chrome.
67 410sb 11.63 @117.6
Old Apr 23rd, 00, 04:04 AM
Sam68 Sam68 is offline
Talking
Someone made a comment on window regulators. That is absolutely correct. I learned the hard way...hehehe. I had no interior for my 68 convertible so figured I would go with all deluxe. Looks real good, but I haven't swapped regulators and it is a real nightmare trying to get windows up and down. Not really a problem though. Top stays down year round. If it aint nice outside,,,,the car stays in the garage.
Sam
Old Apr 23rd, 00, 04:42 AM
Post
Window regulaters also different? Is that true with 67's too. In that clunker 68 I just bought, it had no interior so to speak but there were deluxe door panels laying on the floor with the window regulaters. What is different?, and wouldn't the doors themselves have to be different if the hole is located in different place? We may have to post new topic on this to get some feedback, this is driving me crazy now.
Steve
Old Apr 23rd, 00, 05:02 AM
ragtopman ragtopman is offline
Jim
Post
Of course you can change it. Just go and ask your mom, I mean your wallet first(just a little humor). All new seat buns, front and rear. Deluxe door panels, front and rear and deluxe front and rear window regulators. The shafts are longer than a standard due to the different panels. But there nice when its all done.
