Rear end compatible? (12 bolt from Impala) - Team Camaro Tech
Thread Tools Display Modes
Old Feb 11th, 07, 07:53 AM
shoe shoe is offline
Jeff
Default Rear end compatible? (12 bolt from Impala)
Guys,
Is there a quick way to cross reference some rear ends so I can find a 12 bolt for my 68? Local shops around here want up to $2000 for a used one. Crazy.
I saw an ad for a 66 Impala 12-bolt, but it isn't nearby and he hasn't measured it.
Just looking for some compatibiliy to make my shopping easier. Thanks!
-shoe
Old Feb 11th, 07, 08:04 AM
DOUG G DOUG G is offline
Default Re: Rear end compatible? (12 bolt from Impala)
68-74 (may be some 75+)
Nova
Omega
Ventura
Appolo
68 Camaro~LSx
Best to Date....and tuning
1.546 60'
7.132 @ 94.43 660'
11.327 @ 116.79.
RedЯum <-Pics
https://youtu.be/Of8WVNYhR1g <~More here
Old Feb 11th, 07, 08:39 AM
Rarerat's Avatar
Rarerat Rarerat is online now
Nick
I used a 69 Impala 12 bolt in my Blue 69 and love it. here is a tread that tells a litte about what I did. I hope it helps
http://www.camaros.net/forums/showthread.php?t=85078
Old Feb 11th, 07, 11:49 AM
big gear head big gear head is offline
Freddie
The Impala rear end can be narrowed to fit your Camaro. I have built many Camaro and Nova rear ends using Impala housings. The housing ends need to be changed. They use the larger truck axle bearings and brakes, but Moser has the correct ends to weld on. The Impala has all of the brackets welded to the axle tubes, so they can be cut off easily and Camaro spring perches welded on. Moser also has those.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: Rear end compatible? (12 bolt from Impala)
Location
Location
First Name
Human Verification
Similar Threads
I need to build a rear end for 86 camaro? sheboygan34 Transmission & Driveline 4 Dec 26th, 06 09:38 PM
67 Chevell 12 Bolt Rear End Fit ? JAKER110 Transmission & Driveline 15 Dec 13th, 06 06:39 AM
Rear end ratio changes? ccmblack Transmission & Driveline 4 Nov 28th, 06 06:16 PM
Rear of hood too high. Brackneyc Body Shop 10 Apr 28th, 06 07:20 PM
12 Bolt rear end ID..... Johnny in AZ Tag Team 0 Jun 27th, 05 01:38 PM
