Fourth Generation 1993-2002
Old Feb 18th, 07, 04:27 PM
syk_pky_dfugate1 syk_pky_dfugate1 is offline
Default 2001 Cammaro has no power going up hills
My 2001 automatic Camaro started acting up a few days ago. When starting up hills it has little power. I checked the transmission fluid and it was low. I added some to it and that helped some. When giving the car gas it seems like the engine is working properly it just doesn't seem to accelerate like it should. Any suggestions on what could be wrong?
Old Feb 18th, 07, 06:00 PM
BillK BillK is offline
Default Re: 2001 Cammaro has no power going up hills
sky,
From your question, it sounds like you are not real familiar with car terms. I would suggest having somebody test drive the car and tell you what they think. It sounds like the transmission might be slipping pretty badly, which can result in an enegine failure as well. Take it to a trans shop and have them drive it. Does your car have a tachometer ? If so, what is it indicating when you have the problem ?
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1971 Chevelle "Heavy Chevy" original owner
Old Feb 19th, 07, 12:18 AM
19HoosierDaddies67's Avatar
19HoosierDaddies67 19HoosierDaddies67 is offline
Jerry
Just another suggestion. It could be your catalytic converter. I had a company Dodge van that really bogged down going up hills, I could only go 35-40 mph, the rest of the time it ran well. I took it to the Dodge dealership and they replaced the Cat. Van ran great after that.
1967 Convertible Camaro
http://img.photobucket.com/albums/v3...rch2009478.jpg
Member of Cool Runnin Camaros:
http://www.coolrunnincamaros.com/
Old Feb 21st, 07, 08:01 PM
lukeciffer lukeciffer is offline
luke
i was thinking a cat. converter also. being it is a 2001 it may still covered under an emissions warranty. the warranty is 8yrs\80,000mi. it would be covered it the car was setting a cat. efficiency code, but I can't say for sure if it covers plugged cats.
Old Feb 22nd, 07, 06:04 PM
Z28 Mark's Avatar
Z28 Mark Z28 Mark is offline
Mark
Arrow Re: 2001 Cammaro has no power going up hills
You know about the letter from GM about the catalyst converters and the recall / extended warranty on a lot of the 4th gens… Check out this thread in this section:
http://www.camaros.net/forums/showthread.php?t=95998
Mark (AKA Z28 Mark)
1973 Z28 2001 Z28
1974 Corvette
Camaros Limited~Nor Cal
Club Photogragher
Similar Threads
Power Top Switch 327!275hp!Convt! Convertibles 13 Jan 23rd, 07 07:10 AM
overlap, and stock idle L79Mike Performance 13 Jan 21st, 06 10:23 PM
Correct power steering pump and pulley for 69 Z28 jlighthart Engine 0 Nov 15th, 04 03:52 AM
2001 chevy silverado power steering pump jeff8428 Brakes, Suspension & Steering 3 Nov 4th, 03 07:09 PM
Power Steering / Belt Alignment Problem kgaffney Tech 2000 17 Jul 9th, 01 05:36 PM
