Third Generation 1982-1992
Old Feb 21st, 07, 04:58 PM
67dreams 67dreams is offline
matt
Default 4bbl q-jet
ok so heres the deal, i have an 86 berlinetta camaro with one of those damn electronically controlled 4bbl q-jets. the car is running rich right now and i need to fix it up so it will pass the CA smog test. I know the air/fuel mixture is controlled by the ecm so my question is should i use a code reader to reset the computer or is there something else causing it (ive already checked all vaccuum lines and the pcv system, air filter is clean, ect)...Maybe a carb rebuild or just a new carb would help? any advice would be greatly appriciated
Old Jun 17th, 07, 05:56 AM
based baller based baller is offline
Default Re: 4bbl q-jet
i wish you luck! i bought a new q-jet it cost me about $440.00 and did not change a thing! run a diagnostic on it hopefully that will tell you something.
Old Jun 17th, 07, 07:42 AM
kustomwerker kustomwerker is offline
mike
this is going back a long way for me, but look for a map/baro sensor...check to see the vac lines are good to it, and that it is functional...you can get a gm map sensor for about 40 bux...if you scan it, you can pull a data stream to see if it`s working...i`m sure the book gives a voltage test procedure also...it sounds like the auto enrichment valve on the carb is stuck open, either due to the ecm, or gunk on the valve...jm2c...
sometimes you`re the windshield and sometimes you`re the bug...
Old Jun 17th, 07, 08:34 AM
77wolf10.85's Avatar
77wolf10.85 77wolf10.85 is offline
Tim
My 87 Caddy had one of those qjets. Loved the car but never got used to that carb sitting there clicking.
Tim Smith
Old Jun 26th, 07, 04:25 PM
esm632000 esm632000 is offline
eric
I have an 1985 camaro berlinetta with same carb, and the same problem your having please let me know if you figure it out.
thanx
Eric
Similar Threads
502 Ram Jet tobin67 Engine 10 Dec 11th, 07 11:38 PM
Jet size on a Q-jet? Hammer49 Performance 2 Jan 16th, 06 03:01 PM
Hello everyone, newby here with circle track q jet carb questions??? leftwheelup Engine 3 Jul 9th, 05 08:54 AM
Holley jet size conversion Mister G Bench Racing 3 Jun 24th, 05 04:53 PM
Speed Demon jetting update Eric68 Performance 19 May 3rd, 05 05:03 AM
