| Team Camaro Tech Current Topic: Windshield wiper arms....they suck... | ||
| Fourth Generation 1993-2002 |
Why is it that they were made upside down??? The stupid "J" hook that you attach the wiper blades onto is upside down, making my wiper blades leave gaps on the windshield when they are used....is there ANY way around this problem???
Our insurance policies are lacking; however, our balls are enormous. |
Spray the windshield with foam glass cleaner so you can see the contact pattern.
Turn the wipers on, and then use the ignition key to stop them mid-arc. You will see an obvious gap where the blades don't touch the glass. Carefully bend the metal part of the arm to get full contact against the glass. Of course you want to be careful and not break the part of the arm that is plastic. Then again check your work using the foam glass cleaner.
Don ~ TC Member #15 Gold |
another problem is rust in the pivot point...wd40 at the pivot and the above post will probably get you going...
sometimes you`re the windshield and sometimes you`re the bug... |
I have the exact same problem on a 1995 camaro. The driver's side wiper does not fully contact the windshield throughout the entire sweep. It's SO frustrating. I've ordered a replacement wiper arm hoping that will fix it, but now after reading this I have my doubts. But.....what is the problem? You shouldn't have to go bending brand new wiper blades in order to make them contact the windshield. That's just a bandaid. What is the fix?
Similar Threads
| Wiper Arms | Barry H | Body Shop | 2 | Oct 24th, 05 10:16 AM |
| Windshield Wiper Pressure | Seakane | Camaro Tech | 13 | Jun 13th, 05 12:04 PM |
| windshield wiper motor does not work | hobackriver | Electrical & Wiring | 5 | Jul 17th, 03 05:52 AM |
| Calling all wiper arms! | coach420 | Body Shop | 17 | Jun 19th, 02 08:00 AM |
| windshield wiper help | 68SS396 | Tech 2000 | 2 | Jun 23rd, 00 11:06 AM |
