| Team Camaro Tech Current Topic: Help pls. 89 rs 305/tpi to 350/carb wiring | ||
| Third Generation 1982-1992 |
I just swaped over from a 305/tbi to a 350/carb and when I turn the key the starter dont run. I am pretty sure I wired everything I needed. Does anyone have or can anyone draw out a simple wire diagram pls? Everything else works in the car and under the hood just no starter turn when the key is turned on
check for power at the momentary wire to the starter...its the thick purple wire that goes between the waterpump and engine...you could have cut it when removing tbi wires...did you cut tbi wires???lol???
sometimes you`re the windshield and sometimes you`re the bug... |
Similar Threads
| 67 wiring diagram | JOHNRSWEAT | Electrical & Wiring | 2 | May 5th, 06 08:44 PM |
| Ignition switch wiring problems | bwhitfield | Electrical & Wiring | 4 | Jan 10th, 06 09:38 AM |
| Rewiring the car... | mbmmca | Electrical & Wiring | 13 | Nov 23rd, 05 01:27 PM |
| 1967 Camaro 350 Ignition wiring question | Mean_Gene3 | Engine | 6 | Oct 2nd, 05 12:50 PM |
| engine wiring harness, extra wire? | tdpole | Electrical & Wiring | 15 | Jan 30th, 02 05:34 AM |
