| Team Camaro Tech Current Topic: 1994 Camaro With Problems. Plese Help! | ||
| Fourth Generation 1993-2002 |
I have a 1994 Z-28 that I recently change the starter on. When I tried to start the car nothing happened. The main hot wire from the battery to the starter had power but the wire coming from the key switch to the starter didn't have power at the starter. I ran a wire from the battery junction box, to a in-line fuse, to a switch in the cab, back to the starter. The engine starts normally but will only run few about a 1-2 seconds and then will shut off. What could be the problem?
do you have the theft key system and if you do then you have to take the steering wheel off and replace it key lock because i have had the same problem
does your theft light blink and if it does you have to change the key lock because you have the theft system
Similar Threads
| 69 camaros on television and movies | jsg1010z | Bench Racing | 30 | Dec 3rd, 07 02:05 PM |
| 1994 Camaro and Power Windows | wmartin | Electrical & Wiring | 1 | Jun 9th, 06 05:17 PM |
| '99 V6 Camaro Clutch Problems | thisguy07 | Troubleshooting | 1 | Dec 16th, 05 07:53 PM |
| 1968 camaro 4 piston brake problems | ruwicked | Brakes, Suspension & Steering | 4 | Jun 4th, 05 01:56 PM |
| 5th Gen Camaro in 07? | 69ProTouring | Bench Racing | 6 | Sep 16th, 03 12:24 AM |
