rear window defroster switch. - Team Camaro Tech
Heating & Cooling Heating, cooling and air conditioning
Old Mar 1st, 07, 03:18 PM
stevo camaro's Avatar
stevo camaro stevo camaro is offline
Question rear window defroster switch.
Anyone know where they were located? There was one in the car, but wire was cut & I never could find a switch. This is 67 without air.
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 Salvaged RS pro street project, ready for floors & motor.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
77 Trans Am, complete, sitting.
55 210 post, 2 door.
Some mornings, it's just not worth chewing thru the leather straps"
Old Mar 1st, 07, 05:13 PM
gene_sc gene_sc is offline
geneo
Default Re: rear window defroster switch.
square hole left of the steering column, bottom of instrument cluster (same hole as convert top switch). switch should be a round knob if I remember correctly.... its in the assembly manual
Old Mar 1st, 07, 05:21 PM
Thanks gene
Old Mar 1st, 07, 05:23 PM
tonycamaro tonycamaro is offline
Tony
Steve,
I have one if you need it.
Tony
Similar Threads
Rear Window Installation norcalcamaro Body Shop 14 May 17th, 06 08:01 PM
Would you use the top with a plastic or glass rear window Mark .L.W. Convertibles 11 Apr 6th, 06 10:24 AM
Rear Window Rust fixalldude Body Shop 1 Sep 11th, 05 07:10 PM
Rear window and trunk rickl0701 Body Shop 4 Aug 18th, 05 07:15 PM
rear window defroster lever kcs Interiors 1 Dec 18th, 04 02:22 PM
