| Team Camaro Tech Current Topic: High idle problem | ||
| Third Generation 1982-1992 |
I have an 86 z28 and I'm having an idleing problem. When I start the engine it idles at 2500 rpm. Within about 5 minutes it rises to 3000 and seems to just keep climbing from there. Ive been told it could be the choke, a vacume leak or a problem with the carburetor witch is a 2 barrel rochester quadrajet. Any advise would be greatly appreciated!!!
It can't be a Z/28 if it has a carburetor, the Z/28 in 1986 would have tuned port injection and be a 305.
On the right side of the carb there is a choke unloader valve. Check it for a leak. To check it, first remove the vacuum hose, then compress the link sticking out of the valve, cover the hose nipple with your finger and release the link. If the diaphragm is good, the link will not extend itself more than just slightly. If there is a hole in the diaphragm, the link will extend fully, and when you remove your finger, it will not extend more. If the choke unloader does not work, the choke can stay on and the engine will run rich and at high speed. Also check your choke. David
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com 67 RS 327 original owner. 69 Camaro Vintage Racer, 65 Lola T-70 Chev SB Can-Am Vintage Racer |
Unless that was a joke, like my old front-wheel-drive Jeep Wrangler... (I once drove the Jeep, still under warranty, into the dealership service line, the service writer asked me what the problem was, and I told him "it drives like crap in Front Wheel Drive". He got a really confused look on his face and asked me what I meant. I reached down in the passenger floorboard and picked up the rear driveshaft with 2/3 of the fragged slipyoke still attached and handed it to him. He still didn't quite get it, but I thought it was funny. It was a pretty spectacular failure--blew apart the tailshaft housing of the transfer case too, and the driveshaft swung around and tore the muffler almost in half and left a nice gash in the floorpan.) |
no im not kidding it has a "2 barrel rochester quadrajet" if you want i'll even send you a picture!
Reads like a vacuum leak. Check are nipples and their hoses to make sure the hoses are in good shape and no splits and have not fallen off from their nipples.
Did it run good before? Did it high idle gradully or all at once?
Give a man a rescue dog for the health of his soul. My 68 Camaro http://www.flickr.com/photos/everettwn68 |
please do, I gotta see that.
Pat, please only post your question in the 1 section that is most proper for it. Multiple posts are against TC policy, it makes it hard for folks that respond to find which one they replied too. Engine is probably the best area for this. Thanks for understanding.
Click..is Jim..69RS-LM1 350/255 - 700r 4speed auto. "There will come a time when you believe everything is finished, That will be the beginning." Louis L'Amour Our Camaro Webpage Photos for viewing Learn How To Post Pics here |
Quad = 4 as in 4 bbl so you may have a 2 bbl but it's not a "quadrajet"
Not in CA... Because of smog laws here the '86 wouldn't be registered and legal to drive without the orig configuration under the hood.
#11
http://www.thirdgen.org/1986-chevy-camaro
#12
#13
chances are, the car is throttlebody injected...is there 2 sets of wires going to the top of the "carb"???if so, you probably need a throttle body base gasket...common problem with them...
sometimes you`re the windshield and sometimes you`re the bug... |
#14
I owned a 1985 Z/28, (305 TPI) and an 89 IROC (350 automatic, dual cats). I believe the car has a 2 barrel carb now, no need for proof. I'm just saying that combo is not a Z/28 engine. Check out the choke unloader valve and be sure it's getting vacuum from the engine. David
#15
I had the same problem. I own an 86' Z28 and an 92' RS. The 92' was TBI and had no idle problems. However, the 86' which I bought last summer as my project always seemed to idle high when it started and seemed to climb in a few minutes. The Z28 is a 305 4bbl H.O. I found out it was all computer controlled. So...I went and changed the son of a gun! No more idle probs. : )
Similar Threads
| 850 DP hesitation | Mister G | Performance | 21 | Dec 18th, 06 08:19 PM |
| Idle problem | tawodi | Camaro Tech | 1 | Jul 14th, 06 09:16 AM |
| Idle problem | 69BZ28 | Engine | 2 | May 29th, 06 02:14 PM |
| Big Cam Bad Idle :( | Badcaiman | Tech 2002 | 16 | Jul 6th, 02 06:32 PM |
| Idle problem | clash69 | Troubleshooting | 4 | Jan 6th, 02 04:41 PM |
