68 Emblem placement - Team Camaro Tech
Body Shop Paint & Body Forum
Old Mar 6th, 07, 07:02 AM
68-firstcar 68-firstcar is offline
Brent
Default 68 Emblem placement
I need the vertical and horizontal dimensions to place the "327" emblems on the front of my fenders. I need vertical dimension from fender body crease to bottom of emblem and horizontal dimension from front edge of fender to front-most edge of the "3" and "7" (right/left sides). Thank you!
Old Mar 6th, 07, 07:32 AM
z28station z28station is online now
Tech Team
George
Default Re: 68 Emblem placement
Do you have an assembly manual if not i would suggest getting one because it has this information in it and could also be helpful in other areas.They can usually be purchase for about $20.
Old Mar 6th, 07, 07:48 AM
Gary L's Avatar
Gary L Gary L is offline
"Tri-Tip"
Speaking of the AIM, what is the reference line measured from? My front emblems have a "circle 20" as a reference.
"Government is not reason; it is not eloquent; it is force. Like fire, it is a dangerous servant and a fearful master." ..... George Washington
Gary,TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original.
Old Mar 6th, 07, 08:18 AM
gene_sc gene_sc is offline
geneo
vertical distances = Datum line (from frame specs)
horizontal distances= from firewall (0)
Old Mar 6th, 07, 09:14 AM
Gary L's Avatar
"Tri-Tip"
Thanks Gene. From the top of the frame and what point on the firewall? Seems like these would be tough measurements to make. Is this indicated in the AIM?
Old Mar 6th, 07, 09:20 AM
ARD122 ARD122 is offline
Tech Team
Albert
I purchased the emblem templates from ricks first gen and they were perfect. they were to scale and included the hole sizes that you need to drill. good luck
Similar Threads
Emblem placement - Does this look correct? paul1969 Body Shop 19 Jan 27th, 08 06:41 PM
CAMARO fender emblem placement orange 68 Body Shop 3 Feb 16th, 07 08:01 AM
1969 "Camaro" correct emblem placement, above or below? ratbikeharley Body Shop 6 Aug 24th, 06 06:42 PM
68 Glove box Camaro emblem installation Liveinaz Interiors 3 Feb 28th, 06 07:02 PM
correct emblem placement thorpe67RS Restoration Corner 5 Jul 5th, 04 05:29 PM
