 Ground Up Restorations
Second Generation 1970-1981
Old Mar 6th, 07, 12:36 PM
BBchevymotors BBchevymotors is offline
Zac
Default sub-frame connectors
What do sub-frame connectors really do for the car and do i need to get some for my 73'.
Old Mar 6th, 07, 01:00 PM
67 Convertible's Avatar
67 Convertible 67 Convertible is offline
Steve
Default Re: sub-frame connectors
If you hit the seach button and type in "sub frame connectors" there are many threads and lots of reading that should get you up to speed.
'67 Marina Blue Convertible. L30, PG. All numbers match, 41k original miles.
"The only time you have too much fuel, is when you're on fire"
Old Mar 6th, 07, 05:12 PM
BIGBLOCK70Z BIGBLOCK70Z is offline
Tech Team
johnnie
THEY WILL HELP YOUR CAR AND YOU TREMENDOUSLY, YOU MUST HAVE THEM. YOU NEED THEM, YOU HAVE NOT GOT THEM YET. WHAT ARE YOU WAITING FOR. THEY WILL AND DO KEEP THE TOP OF THE DOOR GAPS FROM HITTING. THE BELLY OF YOUR CAR IS SAGGING. PLEASE GET SOME.
Old Mar 7th, 07, 11:05 AM
jdove jdove is offline
Don't buy them from Jegs they won't fit. Buy the CE's..That was my experience.
78 Z28 BB
Sold!
Old Mar 9th, 07, 07:14 PM
Z15CAM Z15CAM is offline
Ron
If you're putting out substantial Hp and Torque, Sub Frame Connectors will prevent the Front Sub Frame from walking which in turn causes the front wheels to rub the inner fender wells and keeps the alignment true; also, will prevent the roof from cracking were it joins to the rear Quarter Panels - been there done that ))
Z15CAM - There was a Viper in my Rear View
This is my 701/2 z28
http://www.flickr.com/photos/28082975@N04
Old Mar 10th, 07, 10:22 AM
77thor's Avatar
77thor 77thor is offline
Fred
They are a must for any uni-body car, IMO. (Street, track, or touring)
They will help prevent the body flexing/twisting and stop the body sag which causes the doors to become out of alignment.
They will stop a lot of the rattles, creaks, and groans caused by the body being twisted.
1969 Camaro SS 350
Old Mar 10th, 07, 10:37 AM
JimM's Avatar
JimM JimM is offline
Jim
I used to "pishaw" them... then I started noticing my vert was sagging, door gaps getting funny when I jacked her up. I welded in Hotchkiss bars this winter. It hasn't even sat on it's wheels yet and I am a 100% believer. These things made my ole baby strong, stronger than she ever was before.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old Mar 13th, 07, 11:37 PM
CamaroTPIPOWER CamaroTPIPOWER is offline
JeffD
I put a set in my 70 camaro rs and the first speed bump I hit my car stopped instead of rolling over it. Before I put a set of them on it would roll over it..... what I meant to say was twist over it. Get some (any) I got the bolt in ones. When my suspension is complete will be welded in place. They work very good I recommend a set
Old Mar 13th, 07, 11:48 PM
CRASH69 CRASH69 is offline
Old Mar 16th, 07, 10:46 PM
ace's68 ace's68 is offline
john
get the weld in ones. and if you want you can even get some square tubing and do it yourself. I know people who do this all the time and just as good as any others. dont get the bolt in kind....
The only Mustang I'd ever own is a Fender.
Old Mar 17th, 07, 09:22 AM
brucelbryan brucelbryan is offline
bruce
they are a must if you are running high hp application. As mentioned, only bad things can happen to a unibody car if not re-inforced, i installed comp engineering bolt-ons and they work great. great insurance!
70 cuda 383
69z28/rs
03 z06 vette
05 srt-10 505ci quad cab "yellow fever"
"its never fast enough"
Similar Threads
sub frame connectors weld them or bolt ? Quick_68 Performance 11 Jun 16th, 08 09:37 AM
Body moounts and welded frame connectors. duckbutter69 Brakes, Suspension & Steering 4 Feb 2nd, 07 01:46 PM
No X brace with frame connectors? mnm99 Convertibles 18 Jun 16th, 06 06:58 PM
Sub frame connectors 302Z/28 Brakes, Suspension & Steering 11 Apr 6th, 06 07:16 PM
Have You Guy's Seen Those New Frame Rails And Connectors Leadfoot1 Brakes, Suspension & Steering 3 Oct 12th, 05 07:58 AM
