Pro Touring Todays performance with classic style
Old Mar 6th, 07, 10:52 PM
cody cody is offline
Default How to make a fiberglass hood straight
Learned the hardway that no matter how great it sounds, or how much money you spend ALL fiberglass hoods are junk(well at least %95 of them are. This is a custom made 3" cowl hood/bolt on from VFN. Took a lot of blocking and a lot of coats of filler to get it where it is.
71 formula firebird, 468; AFR rectangle port, 11-1 compression, Isky Solid Roller 290/294,...620HP, Viper T56 six speed, 19" CCW rims, Hydroboost, C5 corvette brakes.. currently being built(almost done)http://www.formula454.com
Old Mar 7th, 07, 03:07 AM
madmax87's Avatar
madmax87 madmax87 is offline
Gold Member
Default Re: How to make a fiberglass hood straight
Thats what has my leary about getting the Stinger hood. I seen them on a few cars but never really heard about the problems getting them to fit properly.
Dennis
69 Z/28. 302DZ, Autogear M22, Red w/black stripes.
69 Camaro, ZZ4, TH350. 8.5 3:42 posi, X11 (in progress)
87 IROC (in progress)
86 Z28 (Not sure what state that's in)
Old Mar 7th, 07, 05:18 PM
Its not about the fit, but more so about the straightness or waviness of the hood.
Old Mar 8th, 07, 10:46 AM
Mark SC&C Mark SC&C is offline
Tech Team
We found great product for doing parts and panels like that. It`s a spray filler/etching primer called Rust Defender.
(get it,rusty fender ). There are other brands but this is the only one I`ve used. 3 coats layed on heavy will fill deep 40grit scratches and it sands really nice. We usually do one layer of regular filler where the big low spots are,block out with 40grit on a long board,hit it with 3 coats of spray filler,block it with 80grit,hit it with 3 more coats and block it with 180 then do 2 or 3 final coats with it thinned a little more then do the final block sanding. We were really skeptical but it saves a LOT of time and does a really nice job. The only downside is it runs about $100 gal. and you go through quite a bit when you mix it thick and lay it on heavy. Mark SC&C
--Savitske Classic & Custom--
Pro-Touring,Hot Rods,Muscle Cars
-Cutting Edge Suspension Products-
SPC,Varishock,Spohn,Baer,Howe,ATS
Chassisworks,Lee Power Steering,Currie
www.SCandC.com NEW!tech@scandc.com
(610) 346-8805
Old Mar 8th, 07, 10:53 AM
That sounds good. We did about 3 coats of filler and then a final coat with Evercoat Easy sand which is a polyester putty. We are going to do the entire car in Polyester Primer(filler primer) which we will spray on really really thick, like 4 coats at once. Then block that off and then finish with a urethane primer. Should come out really straight. This hood was wavy as ****
Old Mar 8th, 07, 11:32 AM
jet_car2000 jet_car2000 is offline
Frank
Dennis you might want to look at the new stinger hood Ricks has now,,seen them and plan on getting one in the near future,,Frank
1968 vert
1967 RS/SS
1967 base 210 glide
Old Mar 8th, 07, 12:18 PM
Everett#2390's Avatar
Everett#2390 Everett#2390 is online now
Drive a '68!
Strange, my Unlimited Products cowl hood is straight, had it for 12 years now.
It all depends upon the model used to make the mold.
Give a man a rescue dog for the health of his soul.
My 68 Camaro http://www.flickr.com/photos/everettwn68
Old Mar 8th, 07, 02:12 PM
madmax87's Avatar
Gold Member
I'll do that. Thanks!
Dennis
Old Mar 8th, 07, 02:38 PM
camcojb camcojb is online now
Jody
you have no idea how strange that really is!
Jody
new updated website!
64 Chevelle twin turbo LS2
Old Mar 9th, 07, 12:17 PM
BBCamaro BBCamaro is offline
etch primer is in no way meant for filling scratches, if it fights rust it does not fill, and if it does it will shrink down into the scratches after a few months.
polyester primer is for doing ultra ultra straight paint jobs and or vettes and fiberglass parts, its name in the tech manual is "sprayable filler"
1968 Camaro streetfighter, 18x10,18x12 ccw's,tq arm rear,apex c6 front sub,ls6 asa cammed dry sump,t-56,335/30/18 and 275/35/18 toyo r888
www.jakesrodshop.com
Jake's Rod Shop
207-595-0677
Old Mar 9th, 07, 12:19 PM
To add to this, IIRC etching primer and filler do not go together right? Since the etch is acidic or something like that
Old Mar 9th, 07, 12:22 PM
BTW unlimited is known to make the worst fiberglass products on the face of the earth, but after this VFN I'm not sure if anyones is really much better than another
Old Mar 9th, 07, 01:59 PM
edd Gordon edd Gordon is offline
Edd
I watched an episode on Dream Car Garage on how to make a fiberglass hood-- They laid it all out in a mold then vacuumed it and if You watched the show You could tell how much better they built that hood then a regular fiberglass production shop could make them. I watched the guys at Ecklers Corvette make fiberglass hoods and they didn't do it like Dream Car Garage did and You can see the difference in the final results.
Edd Gordon 68 Camaro SS350 now SS 406 96 SLP SS Camaro
Old Mar 10th, 07, 03:08 PM
Steptoe Steptoe is online now
Steps
I used to own a fibreglass manufacturing company...we produced everything from repro fenders, bus body panels, Foden and Mac truck panels, boat, caravans beach buggies to commercail air conditioning ducts.
The quality of the product depends on several things
1/the quailty of the orginal plug
2/The stiffness of the moulds
3/The skill on the guys on the chopper gun and the guys rolling out
4/ How the units are braced in the moulds before release
5/how fast the units are popped out of the moulds
6/Moulds do wrarp over time...we used to get 60 to 150 units from a mould, depending on the accrucy the customer required...some units like horse float roofs that could not be seen on top did not require the same finish.
The main issue with fiberglass is manufacturers pushing limits beyond the real lifetime of the moulds....making quality plugs/moulds is time comsuming and expensive.
Hence maybe the reason of comments above...re a unit obtained yrs ago and a recent on.
Fixing a warped unit....this can be done, but requires a lot of work...usually involving cutting and reshaping before even looking at any high and low areas.
Most of these can be 'pulled' out during the reshaping..
Similar Threads
Hood Squaring Fixture BlackCamaros Body Shop 6 Jul 5th, 05 08:05 AM
fiberglass (or not) hood tips please 68rs406 Body Shop 12 Oct 4th, 04 07:42 PM
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 02:45 AM
Adjustment to fender? Winch Body Shop 4 Mar 10th, 02 02:46 PM
Fiberglass Cowl Hood Q's... ohayden Body Shop 6 Feb 27th, 02 07:35 AM
