GM Piston #3888304 ???? - Team Camaro Tech
Thread Tools Display Modes
Old Mar 7th, 07, 08:28 AM
jch1805 jch1805 is offline
John
Default GM Piston #3888304 ????
Guys I hope someone has some info in this piston #. Scoggin & Dickey nor GM can do anything with it. I purchased this engine sight unseen for $500.00. Went later that night and picked it up. It has 990 rectangular port heads, block casting number is a 361959 and the casting date is 76 and the casting date on the heads were 74. The block is std. bore.
I am trying to determine what compression the pistons are. Your input is needed. Thanks !!!
A person's word is their legacy.
67 Camaro, Hugger Orange w/BBC (new edition)
73 RS camaro BBC with 91mm turbo (sold)
69 hugger orange X44 for the wife(sold)
Old Mar 7th, 07, 09:45 PM
Rewind Rewind is offline
James
Default Re: GM Piston #3888304 ????
Not alot of info but , i joined so i could pass on info i remember seeing maybe it will help . I've read a few things about this piston number .
" TRW L-72 replacement pistons used that number . Compression would be between 11.2 and 11.5 depending on chamber size, quench, gasket thickness, etc... That is with Closed chambers of 108 to 110 cc. Dome is about 23 cc. " From the first link below ...
990 head is a 118 cc chamber head so your compression will be less . These links have the info above and maybe some more . Hope this helps in some way for info you need
http://www.chevelles.com/forums/show...hlight=3888304
http://cgi.ebay.com/ebaymotors/66-69...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/bbc-p...mZ120082159078
Old Mar 8th, 07, 02:00 PM
John
Thanks for the help !!!!
Hope to return the favor sometime.
Old Mar 8th, 07, 02:20 PM
zdld17 zdld17 is offline
Don
361959.....454.......73-90...2 or 4 bolt
Mortec site.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: GM Piston #3888304 ????
Location
Location
First Name
Human Verification
Similar Threads
Secondary Piston on 69 disk brakes blackss69 Brakes, Suspension & Steering 0 Apr 10th, 06 12:44 PM
Piston balancing question davidpozzi Performance 30 Sep 5th, 04 04:11 PM
Using a piston stop to time my motor 67killerb Engine 2 May 13th, 03 04:44 PM
Changing to dual piston calipers, question about braided brake hose cottonpicker14 Brakes, Suspension & Steering 3 Apr 17th, 03 03:28 PM
Piston to valve clearance Iceman41 Engine 2 Dec 23rd, 01 08:43 PM
