Fourth Generation 1993-2002
Old Mar 11th, 07, 02:08 PM
94TwitchZ28 94TwitchZ28 is offline
Tech Team
Angry This thing sucks!!!
Just had the stock trans in my 94 Z28 fully rebuilt...all high friction clutches bands and had a street and strip **** kit and a 2500 stall converter put in...so tell me why when I mash on it does it rev real high (almost 6,000 rpm) and then drop down...(I have ceased driving the car for this reason)...Im pretty upset right now because 3rd gear and 4th gear and the over drives are GONE...all I have is second and first ...is there something stronger I can get because Im going to have this one rebuilt again (It was rebuilt 1 month ago)by the same place (rebuilt at AAMCO) and if it happens again Im gonna have them buy me a new trans...What kind of options do I have other than stock with a shift kit?
Old Mar 11th, 07, 05:02 PM
jaguareats jaguareats is offline
bill
Default Re: This thing sucks!!!
they make high performance clutches and bands for that transmission. also dont know what kind of shift kit they used.also is it the 4l60 or the 4l60-e
Old Mar 11th, 07, 08:39 PM
South Side Goons & Hitmen South Side Goons & Hitmen is offline
Gold Member
I know the 4L60E is the modern version of the 700R4 which became the 4L60 then the 4L60E. On the 700R4's if the Throttle Valve cable was not set correctly it was a big issue. Some transbuilder's would use the Corvette servo to help increase line pressure.
This is why I always preferred a full manual valve body. There are less headaches with full manual valve bodies.
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, needs work once again
Old Mar 12th, 07, 06:39 PM
kustomwerker kustomwerker is offline
mike
sounds like the pump casnt creating good pressure from the start...aamco should stand behind the trans if they installed it...tv setup is very important on the 4l60, but the 4l60e is electronically controlled...i dont believe they have a tv system...trans-go makes a good shift kit...dont go with anything bigger than a corvette servo...these trannys dont like a lot of shock load, and are prone to failure due to stress cracks from shock load...personally, i think i`d take it to a guy that specifically does performance trannys...
sometimes you`re the windshield and sometimes you`re the bug...
Similar Threads
hey hard core camaro folks...did i do the right thing? joe clance Body Shop 15 Feb 26th, 07 07:12 PM
What is the best thing to use? blessedfind Restoration Corner 3 Jan 29th, 07 10:24 PM
clutch engagement sucks! help me out MY FIRST 69 Transmission & Driveline 35 Nov 21st, 06 12:05 PM
bling bling this poor thing mgt999 Bench Racing 10 Apr 15th, 05 02:40 PM
