1969 camaro ignition switch instalation - Team Camaro Tech
Thread Tools Display Modes
Old Mar 15th, 07, 04:29 PM
onewickedcamaro onewickedcamaro is offline
Tech Team
Default 1969 camaro ignition switch instalation
I run into a problem... well two. The first is what size srew or bolt that holds down the ignition switch? I have tried 1/4 and 5/16 both don't work. Next is that I found someone took out the ignition switch. I went to napa and bought a new one. The question I have is that rod coming from the key where you start the car is pointing straight up. The switch that I have the rod goes into the switch from the side.. Going from driver to pass side. Do I just bend the rod or do I have the wrong switch?. Also what is the best way to install the switch. Do I leave the key in the lock position and move my switch to match it?
Old Mar 15th, 07, 08:12 PM
Eric Kammerer Eric Kammerer is offline
Default Re: 1969 camaro ignition switch instalation
The actuator rod does point up, and you probably have the correct switch and are just trying to put it on wrong. I will dig up some pictures to post.
Eric
69 'vert project big block/TKO 600 RR
68 'vert driver RS clone -- gone!
Old Mar 15th, 07, 08:15 PM
Theres a photo at the bottom of this post, but I am looking for a better one...
http://www.camaros.net/forums/showth...ion+switch+rod
Eric
Old Mar 15th, 07, 08:19 PM
Some good diagrams and instructions at this link. Look at the standard 69-76 column info and pics.
http://jimshea.corvettefaq.com/?page_id=5
Eric
Old Mar 15th, 07, 09:26 PM
JIML82 JIML82 is offline
There are two different ignition switches. One type for tilt columns the other is for the standard (non-adjustable) columns.
You didn't mention which type that you have.
You can go to www.corvettefaq.com
Click on Jim Shea Steering Articles
Click on A & F-Car Steering
Scroll down to either the 1969-76 Standard Column or the 1969-76 Tilt Column sections
Download Paper #3 and Pic #3 (The paper and pic have instructions on installing and adjusting the ignition switch.
Old Mar 15th, 07, 10:02 PM
Tech Team
You are right, I have the standard column.
Old Mar 15th, 07, 10:21 PM
Tech Team
Thanks great information but still not a good picture of where the rod goes into the switch. I looked at the bottom of the switch but cannot see any where the rod can go??????
Old Mar 16th, 07, 11:47 AM
Maybe the picture in the middle of the page will help.
http://jimshea.corvettefaq.com/wp-co...2Rev04MR03.doc
JIML82
Old Mar 18th, 07, 11:00 AM
Tech Team
Thanks Jim and Eric with your help I got installed.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Electrical & Wiring      Current Topic: 1969 camaro ignition switch instalation
Location
Location
First Name
Human Verification
Similar Threads
86 camaro ignition switch lysa Troubleshooting 4 Jul 30th, 13 08:55 AM
2 1969 ZL1 Camaro Prototypes 68Baldwin Copo & Dealer 57 May 11th, 09 06:43 PM
Pics of rs headlight system components 67 Sinner Electrical & Wiring 11 Mar 6th, 07 08:54 AM
ignition switch 94camaro Troubleshooting 1 Feb 22nd, 07 06:44 PM
Ignition switch removal on 67 camaro prostreet L-78 Tech 2000 6 Jun 16th, 01 07:10 AM
