| Team Camaro Tech Current Topic: Need help with suspension options and upgrades | ||
| Pro Touring Todays performance with classic style |
![]() http://www.artmorrison.com/2006cat/35.pdf http://www.detroitspeed.com/productpages/subframe.htm Alright, Guys here is my car and these r two of the frames i am looking at to up grade my front suspension. My car needs a new powersteering gearbox, new brakes and bushings and pretty much all of the front suspension. i want as little down time on my car as possible but i also want a reliable frame So guys would U Buy a new aftermarket frame or would u buy a donor frame and transfer new parts to it My plans for my car r as follow I am pulling the 383 and going back with a LS1 or ZZ4 block depending on funds after suspension and paint I want a good cornering and streetability so as to keep up with higher end cars Thanks for the input Also any rear suspension options would be appreciated as i have not started researching them yet Dusty |
How much you want to spend? Both of those are very nice & lots of $$$$$. And that includes wheels, tires & brakes. It's all a package and you'll find your weak spot fast. I could see complete deals breaking $15k without trying real hard.
Better question: What is the intended use: All street. Road Racing? AutoX? That matters. If it is all street, I think a lot of stuff out there is overkill. Goals & $$$. That will help you back into the right answers. |
Well scott I have the money for the frame and from what i have seen it would cost about the same to restore my stock frame with new products my intentions r to start buy getting the frame and engine first then brakes and wheels next year seeing as though i will wait till i have everything to start dissassembling my Car and i can buy cheaper brake set ups than the name brand but the suspension is pretty much uniform
hey man look at the link I have pics of the frame that I bought.
Got to give the PEOPLE what they want! Look....if you wanna be the best then you gotta take out the best! 1967 Prostreet Camaro BB 431 650hp 400 Turbo Trans Ford 9" 4:56 gears http://www.cs3automotive.com/index.php |
Hey matt what kinda frame is that what did u give for it and were u happy with it
I'm putting mine together right now and I went with basically everything new except the sub frame.
Using DSE UCA,LCA pitman, idlers, tie rods, Quick Ratio steering box, Baer master cyl, booster, Baer Track 4 wheel disc, Hotchkis TVS and QA1 front coil overs, Billet Intro wheels and tires for just about $7,000. Whew that's a lot to say Not too bad considering everything I got. If time is a factor then you might just do something similar. Unless you have alot of free time after work and feel like working on your car then maybe the sub frame is the way to go. I will have mine back together by next week. Should be sweet. Good luck. Rich
AFR Heads W/ Jesel valve train http://www.fquick.com/Rich-Allen 67 RS / SS http://eastbayerectors.com/camaro.html |
If you're not in a huge hurry for a subframe, keep your eyes on this one - I understand the basic subframe will be CONSIDERABLY less money than those you linked.
http://www.speedtech-performance.com...rod/prd129.htm |
IMO, the aftermarket subs are nice, but bang for buck they're not worth it.
Don't forget about 21st century street machines if you decide to go with a new sub. http://www.21stcenturystreetmachines...item=subframes Before we can talk about what is right for your car, what are your goals for the car? Weekend cruiser? Daily Driver? Auto-X, Drag Race? If it's street only, that $ spent on an aftermarket subframe will not be realized in performance. Rear leaf springs can be designed to work very well. If you retain the leafs, match them to your front springs. There are many other options to consider, like the Lateral Dynamics 3 link. http://www.lateral-dynamics.com/products/
Steve 1968 Coupe., filled with cool stuff from Tremec, Moser, Ron Davis, Speedtech, ATS, Hotchkis, Forgeline... blah blah blah Check it Out Here |
If you buy an aftermarket subframe, you're paying $4,000 to $5,000 for a marginal improvement in perfromance and a lot of bling. If you've got the money to spend God bless you, go for it; if not, spend it where it'll really do you some good. But unless you're trying to convince a wife/girlfriend , don't try to sell the "it costs the same either way" line here.
Mike - 68 Camaro with some stuff done to it; building another '68 with even more stuff done to it. http://www.camaros.net/forums/attach...2&d=1176782254 |
Don't forget to throw AirRide Technologies, http://www.airride.com/index.asp, in the mix.
Rod 69 Camaro - 355 SBC, 2004R, 12 bolt posi w/ 3.73, Baer 4WDBs w/ Hydraboost, Hotchkis & GW susp, Budnik Cobalts, Marquez Design pieces, DSE dash & Billet hood hinges, Corbeau TRS seats... Smoothing firewall and Upper dash panel replacement |
#11
The frame is from a place in ohio called checkeredracing.com I got everything for 2k. Subframe, mustang 2 rack and pinion, disc brakes, cross drilled and slotted rotors, 2" drop spindles, cross member, motor mounts havent installed it yet bc its gotta welded in to the sub connectors
#12
There's something that needs to be cleared up here.
Aftermarket subframes offer many, many advantages that stock subframes can't offer. Being the engineer here at Art Morrison, I'm running the First Gen Camaro clip on my car, my old subframe was blinged out with all the latest performance pieces: ATS, DSE, BAER, etc. Our new subframe has a geometry that can't be obtained with the stock clip. It's like driving a whole different car. It's pretty much like driving a new Z06. Don't get me wrong, you can do alot with the stock subframe. But if you want to go a little farther, there are products out there that can help you out. However, be very careful about which one you choose. Out of all the aftermarket subframes out there (and I mean all), there are only two I would purchase (ours included). The rest have serious strength or geometry issues (assuming for a handling type application).
Matt Jones Lead Mechanical Engineer Art Morrison Ent. Inc. |
#13
Matt Jones,
Could u post a pic or a link of the subframe that ur running?
#14
Installed photos: http://images116.fotki.com/v701/phot...MG_4380-vi.jpg http://images14.fotki.com/v371/photo...MG_4391-vi.jpg http://images116.fotki.com/v709/phot...MG_4434-vi.jpg Last photo shows a 265/35R18 tire on a 9.5" rim. 275's fit too. These photos are actually the mock-up subframe, the production pieces of extra reinforcements in key areas...and an all around cleaner appearance.
#15
I like that. I only probablem my kit has it that the hole for the rad support is not drilled.
Similar Threads
| Wheel Spacers or other options... | eville | Camaro Tech | 6 | Apr 14th, 07 03:27 PM |
| !!!!Stopping And Turning Extreme upgrades!!! | cDuck28Z | Brakes, Suspension & Steering | 18 | Mar 5th, 06 06:18 PM |
| Headlight Upgrade Options for a 1st Gen Camaro | jay'srs/ss | Camaro Tech | 44 | Feb 16th, 06 10:18 PM |
