rearend decodeing problem - Team Camaro Tech
Old Mar 16th, 07, 07:35 AM
Tom Ashmead Tom Ashmead is offline
Default rearend decodeing problem
I tried to de-code this rearend to find out what size the ring gear is.It is a 10 bolt & dosn't have any "lugs" or "ears" on the bottom of the housing casting.
The pinion nut is 1.125 & it is a multi leaf spring perch houseing.
I think it's out of a 67.
Did they make a 7.5 ring gear that year?
I am looking for a 8.2 & I dont want to buy the wrong rearend.
This rearend is for sale but I didn't want to tear it down in front of the owner if I was'nt going to buy it.
The code is :
PR0702G1.
I de-coded it as a 12 bolt but it's a 10 bolt.
Short of disassembleing it, is there any other way of telling what size ring gear it has?
Thankyou for your time...Tom
Old Mar 16th, 07, 11:05 AM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Default Re: rearend decodeing problem
http://www.camaros.net/years/67/67rearcodes.html
http://www.camaros.net/years/68/68rearcodes.html
http://www.camaros.net/years/69/69rearcodes.html
Take the cover off and measure the bolt heads.....
The 8.2" 10-bolt has a 1 1/8" pinion nut and 3/8" ring gear bolts with 9/16" heads.
The 8.5" 10-bolt has a 1 1/4" pinion nut and 7/16" ring gear bolts with 3/4" heads and left hand threads.
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Mar 16th, 07, 12:36 PM
TJS69 TJS69 is offline
Tom
Smile Re: rearend decodeing problem
Also look here: http://www.novaresource.org/axle.htm
7.5's were not around until the mid or late 70's.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Mar 17th, 07, 09:30 AM
Thankyou...
It looks like it must be an 8.2.
Thanks again...Tom
Similar Threads
intermittent starting and running problem boz2841 Engine 6 Apr 5th, 07 08:58 AM
In Need Of Major Help!! Please!! Justgotacamaro Engine 31 Mar 6th, 07 05:22 AM
intermittent starting and running problem boz2841 Electrical & Wiring 1 Feb 22nd, 07 01:45 AM
intermittent starting and running problem boz2841 Fourth Generation 0 Feb 21st, 07 07:00 PM
Air Conditioning Problem Mark C Heating & Cooling 21 Jul 17th, 05 10:16 AM
