| Team Camaro Tech Current Topic: 87 z28 engine swap question | ||
| Third Generation 1982-1992 |
I am considering a 87 z28 that is perfect condition minus long block and transmission. I plan on putting a 350 with carb, and a 2004r. Does that sound ok so far? I may need a new crossmember? But my real question is do use the fuel pump from the tank or do I switch the car to the block mounted mechanical fuel pump? Will the fuel pressure be ok with a carburator if I use the fuel pump in th etank? I imagine I can install a fuel pressure regulator? Or would it be easier to just use a mechanical pump? Thanks again James
The in tank pump will produce to much pressure, so you could either replace it with a low pressure pump or install a non-fi sending unit and install a block mounted pump. I f you go with an electric in tank pump you will still need a fuel pressure regulator.
Where do I get a non FI sending unit? DO I just get one from a cmaro or firebird that originally came with a carb? Thanks again.
Similar Threads
| 1968 z28 question | 1968z28 | Tag Team | 1 | Feb 2nd, 07 03:21 PM |
| Engine swap question | AgileTick | Engine | 1 | Mar 4th, 06 08:27 PM |
| 1984 z28 305HO to 350 HO swap question. | Ffrizzell | Engine | 3 | Oct 14th, 05 07:10 PM |
| ? about engine swap | clown boy | Engine | 1 | Aug 6th, 05 07:02 PM |
| engine and tranny swap question | jim rex | Tech 2000 | 3 | Jul 1st, 00 06:47 PM |
