Rear axle, line to caliper question. - Team Camaro Tech
Old Mar 18th, 07, 10:36 AM
cdnpont cdnpont is offline
Tech Team
Mark
Default Rear axle, line to caliper question.
Brake guru's,
I'm plumbing my 12 bolt big car axle right now, I've converted to disk. The calipers are 85' Eldorado with 80' TransAm rotors.
I'd like to 3/16 hard line it right to the calipers, instead of using any flex lines, with a double loop at the end to allow the caliper to slide.
My problem is the caliper uses a banjo bolt and crush washer type fitting, obviously I need to end my hard line with a double flare and a male flare nut.
Is there an adapter that you know of to allow me to bring a 3/16 hardline right to these calipers?
Any ideas?
You can see the spot on the caliper where the line is to meet it. It's the green plug.
Cheers, Mark.
Old Mar 18th, 07, 10:54 AM
Mat Klemp Mat Klemp is offline
Team Member
Default Re: Rear axle, line to caliper question.
Yes. There are adaptors that are used. My '79 Seville calipers used them and I grabbed them with the calipers at the pick N pull. They are rectangular brass blocks drilled for a banjo bolt and the side is tapped for the flared tube. You may try to find them at a large parts store, dealer or the yard.
TTFN
Mat
SSCARGO
Old Mar 19th, 07, 10:05 AM
Tech Team
Mark
Thanks Mat,
No luck on the adapters you mention. The banjo bolt on my calipers is Metric as well. 10 x 1.5.
I've just gone ahead and ordered custom braided lines from Inline Tube.
$80 to my door.
Cheers, Mark.
Similar Threads
68 Camaro: rear brake line T? Where to get one 1stgenCR Brakes, Suspension & Steering 2 Nov 4th, 06 06:30 PM
rear brake line routining jdbr1 Brakes, Suspension & Steering 6 Mar 27th, 06 07:22 PM
What to use in in 12 bolt Posi rear and TKO question David Cecil Transmission & Driveline 2 Mar 25th, 06 05:56 PM
Camaro rear axle change man1000 Brakes, Suspension & Steering 0 Jul 28th, 03 04:06 PM
JL8 rear caliper mount bolt pattern Ed Bleich Brakes, Suspension & Steering 2 Dec 7th, 01 02:02 PM
