Third Generation 1982-1992
Old Mar 20th, 07, 05:03 PM
tommy305 tommy305 is offline
tommy
Question 88 camaro problem
i have a 88 camaro with a 89' monte carlo 305 v8 engine my problem is that when i push the gas and have to brake the rpms come down but they come down to where the car acts like it wants to stall out or sometimes it does i have checked for vacume leaks and basically replaced every hose that was bad maybe someone else has a suggestion please?
Old Mar 20th, 07, 08:36 PM
kustomwerker kustomwerker is offline
mike
Default Re: 88 camaro problem
throttlebody motor???clean the iac motor...its the motor on the side of the throttlebody with a square looking plug with 4 wires going to it...unscrew it and clean the pintle and seat in the throttlebody housing...
sometimes you`re the windshield and sometimes you`re the bug...
Old Mar 21st, 07, 04:39 AM
Everett#2390's Avatar
Everett#2390 Everett#2390 is online now
Drive a '68!
The next time you start to stop, place trans into neutral and come to a complete stop. If the engine doesn't stall and trans shifts to 1st gear when selecting Drive, then it might be either a misadjusted/broken brake switch at the pedal, I think. Or a bad solenoid inside the trans, or a loose connection just outside the trans, or a blown fuse.
It reads like the trans is not unlocking from overdrive or from torque convertor lock-up, thus providing more load onto the engine, and it stalls.
Give a man a rescue dog for the health of his soul.
My 68 Camaro http://www.flickr.com/photos/everettwn68
Similar Threads
chevelle lower control arm breakage,a problem with camaro as well?? built4spd Brakes, Suspension & Steering 1 Aug 20th, 06 09:22 AM
Non Camaro tranny problem, need help. ray moore Transmission & Driveline 2 Aug 18th, 06 05:10 PM
91 camaro VATS problem bigd36322 Electrical & Wiring 2 Jun 29th, 06 07:55 AM
Non Camaro question -92 GMC EGR problem Jim H Troubleshooting 0 May 2nd, 06 11:00 PM
more readings I found on up-coming camaro JFINN1976 Bench Racing 3 Oct 13th, 05 10:51 AM
