Bug Hunt Computer related problems
Virus warnings - Technical help.
Old Mar 22nd, 07, 04:14 PM
jr68's Avatar
jr68 jr68 is offline
Team Member
Jerry
Default computer wont turn on
Lightning must have sent a surge through the phone line because it fried my wireless router and the dsl modem. Now the computer wont turn on although it was plugged in to a good quality surge protector. Can I save the PC ?
Old Mar 22nd, 07, 04:45 PM
CDJr CDJr is offline
CDJr
Default Re: computer wont turn on
When you say wont turn on, what exactly does it do? Any lights come on? No monitor? Any beeps?
If its a wireless modem, it shouldnt have travelled to the PC
Old Mar 22nd, 07, 04:50 PM
jr68's Avatar
Team Member
Jerry
No lights or anything
Old Mar 22nd, 07, 04:53 PM
jr68's Avatar
Team Member
Jerry
... and the dsl modem is plugged right in to the pc with a cat 5 wire
Old Mar 22nd, 07, 05:01 PM
CDJr
Ummm, what I would do is look inside the tower aand see if theres anything obvious, such as burnt spots on the motherboard, etc. Most will have a small light on the board that signifies power. If theres no power there at all, you can remove the power supply and if ya have another one, from a different PC, you can try it to see if it only fried the power supply. Theres generally a fuse in the power supply, some are soldered in and some snap in, so you can take the power supply apart and check it. Hope this helps.
Old Mar 22nd, 07, 08:35 PM
TraxUnderground's Avatar
TraxUnderground TraxUnderground is offline
Gary
JR...Its probably your power supply. Smell burt? Was it on when it happened? Poke the power supplies power connector that supplies power to the system bd with a milti meter. You should see 5v and 12v I believe. Man its been a long time since I fried a PS.
Plug it into a good known power source. Pull any optional boards out of the pc to see if one fried and is loading down the pc. Re seat your memory strips and processor.
Good luck
Gary
67 RS Resto-Mod 468 5 spd TKO600 3.73 12 bolt (work in progress but finally on the road!)
http://s96.photobucket.com/albums/l1...Picture328.jpg
http://s96.photobucket.com/albums/l164/traxunderground/
Old Mar 23rd, 07, 04:00 AM
SixtyAte's Avatar
SixtyAte SixtyAte is offline
Kevin
Unplug it from the wall, wait then plug it back in. If it doesn't come on, its fried. There is a fuse in the power supply box but its soldered in. You could try a jumper to see if it boots up then replace the power supply. I have seen many fried things in a computer over the 14 years of repairing/building them.
As others said...probally a power supply/mb shorted out.
Kev
Old Mar 23rd, 07, 01:32 PM
Steptoe Steptoe is offline
Steps
Does the fan in where you plug the main power lead go?
If not, it is not worth while going anyfurther till u replace the power supply box (PSU)in the tower....
Borrow a use one that works from the local computer shop....or buy one, they aren not expensive
Once you have a known good PSU, you can then see if it boots up, how far it boots and start testing...
note these do not protect ftom lightening strike!!! they protect from things like the local boy racer taking out a pole or transforner ONLY.
Be aware, surge can do real werid things, espec if lightning storm thru a surge protector...and the surge protector can be damaged also.
everything may work..but a keyboard causes strange problem
Everything may go well then a few months then the machine starts to crash or the MB just dies one day.
It is best to claim on insurance early on the piece, to do so later causes problems with insurance companies because the actual cause can then not be identified.
I have delt with this problem many times with customers (mainly farmers in rural areas) over the yrs
Old Mar 23rd, 07, 06:50 PM
thedugan's Avatar
thedugan thedugan is offline
Team Member
Doug
How about your phones, fax machine, answering machine, alarm system?
-Doug
68 RS/SS Conv
Restoration started 5/25/07.
Have it for spring 08? Motor is finally done (3/8/08)
Have it by summer 08? Nope
Have it by fall 08? Nope
Have it by Winter 08? No way
Have it by Spring 09? Nope but its made it the the body shop.....
Have it for Summer 09? Possible
Old Mar 23rd, 07, 07:25 PM
jr68's Avatar
Team Member
Jerry
Doug, The phones and everything else in the room work fine. Everything that was plugged into the surge protector works except the PC.
I think the power surge came in through the phone line cuz the wireless router was fried and the cat 5 cable that plugged into that was burnt near the plug , the dsl modem next to it was also cooked. The other PC next to the broken computer which is connected by a network cable was unaffected.
Steps the fan does not function and I put in a psu from another computer and no change.
I talked with CDjr on the phone and he walked me through changing out the psu ( after much discussion on F-body cars ) this guy does it all.
Kev I couldn't find the fuse it must really be buried
Old Mar 24th, 07, 03:03 PM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
If you've changed the PS and the PC still doesn't turn on, it possible the motherboard got fried as well.
The surge could have entered the PC through any one of the hard-wired network connections to it, from what it sounds like.
...'69 Camaro
http://streetmachinesofrochester.com/main.htm
Old Mar 24th, 07, 03:59 PM
Steps
Call the insurance company lol
Old Mar 24th, 07, 05:19 PM
BAMiller BAMiller is offline
Bill Miller
Sounds like what happened to my Dell. It took out the power supply and the mother board. This happened 2 days before the warranty expired.
1969 RS convertible 327 1981 Z28 original unrestored http://photobucket.com/albums/a95/bamillerstingray/
Old Mar 24th, 07, 06:35 PM
jr68's Avatar
Team Member
Jerry
I have a $500 deductible and the computer was a $300 Dell
now I see the printer ( scanner copier ) is shot ---$125
------------------------------my wireless router $75
------------------------------------------------$500 total
coincidence or conspiracy . . . . you be the judge
Old Mar 24th, 07, 07:10 PM
thedugan's Avatar
Team Member
Doug
The main thing is that you get your data off the old harddrive.
-Doug
68 RS/SS Conv
Similar Threads
Crazy Dash Lights and Turn Signals Meanchicken Electrical & Wiring 17 Dec 14th, 06 04:14 PM
68 Turn Signal??? bdcole_51 Electrical & Wiring 1 Sep 4th, 05 06:41 PM
Turn Signal Problem rookie68camaro Electrical & Wiring 2 Mar 20th, 05 04:28 AM
BRAKE lights OUT when USING THE TURN SIGNALS KED67 Electrical & Wiring 5 Jun 26th, 01 04:40 PM
Tail Light Short & Turn Signal Switch KED67 Electrical & Wiring 3 Jun 25th, 01 09:40 AM
