3 Speed or 4 Speed? - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Mar 25th, 07, 04:59 PM
Fewski Fewski is offline
Tech Team
Matt
Default 3 Speed or 4 Speed?
How can I tell if my car is a 3 Speed or 4 Speed? I just bought it and they weren't sure.... I've got the VIN and the tag that is on the firewall. The car is being picked up next weekend, but just kind of wondering.
It's a 1967 327.
Can anyone tell me what number/letter tells me what kind, and what spot it is in?
Thanks!
Old Mar 25th, 07, 05:57 PM
Mark Rossiter Mark Rossiter is offline
Mark
Default Re: 3 Speed or 4 Speed?
Three speed has an 'H' shift pattern. Can't remember off the top of my head where 'reverse' is. Upper left of 'H'?? Four speed has an 'H' shift pattern with reverse coming off of the left leg of the 'H' in the center and then going up.
Too confusing? Take a look at this link on our sponsor's website for the four speed shift pattern:
http://www.ss396.com/mm5/merchant.mv...TERSASSEMBLIES
One sure way to tell is to get in it and drive it. You'll find out in a hurry where reverse is!
1967 Plain Jane Coupe - and proud of it!
Mountain Green w/Black Bumblebee
Old Mar 25th, 07, 06:03 PM
jaguareats jaguareats is offline
bill
if it is on column shift a 3 speed on floor most likely 4 speed in 67
Old Mar 25th, 07, 06:09 PM
JimM JimM is offline
Jim
easiest way to tell for sure is to look at the trans.
3 speeds have 2 levers and 2 rods from the shifter.
Saginaw 4 speeds have 3 levers and rods, all in the side cover of the trans.
Muncie 4 speeds also have 3 levers and rods, but the reverse rod is in the tailhousing, not in the side cover.
Muncie's are alluminum, sag's and 3 speeds are iron.
If you post a pic of the trim tag, we can tell you which it came with.
Old Mar 26th, 07, 06:15 AM
rafbody rafbody is offline
Russ
Look at the cowl tag. A 4 speed car would have an "L" in the second group (2L).
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
'51 Chevy pickup
Similar Threads
speed sensor not working jimijam Transmission & Driveline 1 Sep 19th, 05 03:37 PM
What parts are needed to convert 69 AT console to 68 4 speed Winch Interiors 0 Sep 19th, 05 06:32 AM
Transmission Question 6-speed or 5 speed??? WhiteboysZ28 Transmission & Driveline 5 Sep 8th, 05 08:56 AM
speed governor removal gregscamaro Electrical & Wiring 1 Nov 11th, 03 01:02 PM
What gearing to run with my stall? Luke805 Performance 23 Oct 15th, 02 04:22 AM
