Fourth Generation 1993-2002
Old Mar 29th, 07, 10:34 AM
SPZ28Black SPZ28Black is offline
Shane
Default Knocking problem!
My Z28 has a loud knocking problem comming from the driverside valve cover, this is the second time this has happend in 3 months, the first time i found out it was a broken lifter which cause a dead cylender in # 7 so it was fixed. thenn 2 months later the same problem from what i can hear, what is causeing this lifter to keep breaking?? a bad camshaft?
1995 Z28 6speed, 110,000 miles on body 10k on remanufactored engine, K&N cold air, flowmaster catback.
Old Mar 29th, 07, 04:46 PM
kustomwerker kustomwerker is offline
mike
Default Re: Knocking problem!
where`d ya get the engine???sounds like the lifters are inadequate for the cam lift, or spring pressure...did you have a motor built??have them install a performance cam???where in ct???i`m in new london....
sometimes you`re the windshield and sometimes you`re the bug...
Old Mar 29th, 07, 05:29 PM
JimM JimM is offline
Jim
what did the wear pattern on the bottom of the bad lifter look like? Nice and round and pretty, or a straight groove?
Is this a solid?
Pull the valve cover on the bad side, check and set the lash. If the same one that was a problem before is the problem this time, hang it up and go in for an exploratory.
Fire it with the valve cover off and makes sure all the pushrods are spinning. Pushrod not spinning, lifter's not spinning. Lifter not spinning = bad lobe.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old Mar 29th, 07, 05:46 PM
mike
95 would be a roler motor no???
Old Apr 1st, 07, 07:59 PM
Shane
Im from Stratford, CT, i actually bought it in Norwich ct in early october, the guy said it was remanufactured which i belive because its very clean and my mechanic opened it up, im pretty sure its not a performance cam. I havent had time to open it up yet to see if its the same one but i have a feeling it prolly is, the old one was pretty much chipped pretty bad. Im not an expert with working on cars but i no enough to fix most things, is this something i can do on my own? or should i have a mechanic doit to be safe?
Old Apr 1st, 07, 09:03 PM
Jim
oops, forgot they made Z's after 69!
Jim's NEW Blog!
Jim Cam
Old Apr 2nd, 07, 12:35 PM
Shane
yea its a roller
Similar Threads
intermittent starting and running problem boz2841 Engine 6 Apr 5th, 07 09:58 AM
In Need Of Major Help!! Please!! Justgotacamaro Engine 31 Mar 6th, 07 06:22 AM
intermittent starting and running problem boz2841 Electrical & Wiring 1 Feb 22nd, 07 02:45 AM
intermittent starting and running problem boz2841 Fourth Generation 0 Feb 21st, 07 08:00 PM
Air Conditioning Problem Mark C Heating & Cooling 21 Jul 17th, 05 11:16 AM
