Where to hook up power for electric choke? - Team Camaro Tech
Thread Tools Display Modes
Old Apr 6th, 07, 04:46 PM
tgifford5 tgifford5 is offline
Team Member
Ted
Post Where to hook up power for electric choke?
I have an Edelbrock 1405 manual choke carb. I would like to add an electric choke kit to it. Where have any of you gotten your power source from? Did you splice into a wire? Get it from another part? Any tricks as far as adjusting or setting up the electric choke? This is on a 69, if that makes a difference where to get my power from. Thanks.
Old Apr 6th, 07, 04:57 PM
19694speed 19694speed is offline
Russ
Default Re: Where to hook up power for electric choke?
Any 12 volt source that is controlled by the ignition switch in the run position. I was able to hook mine in an empty cavity on the fuse block with a female wire connector.
Russ
1969 RS conv,hugger orange,396 4 speed,373 12 bolt posi.
My 69 Camaro RS
Old Apr 6th, 07, 05:11 PM
Team Member
Ted
From the firewall side?
Old Apr 6th, 07, 05:39 PM
Russ
no inside the car in between the fuses there are male plugs. Just use your test light and find one that is hot only when the ignition switch is in the run position.
Russ
My 69 Camaro RS
Old Apr 6th, 07, 05:56 PM
JimM JimM is offline
Jim
There are 2 easy places to get power.
If you have replaced the original resister wire to the coil because you added electronic ignition, that one is easiest to tap into, that's the one I used, wire is about a foot long and completely invisible back there. And no, it does not cause any problems with the ignition.
The second place may be even more controversial. The yellow wire on the wiper motor is ignition switched power, it will work fine too.
Old Apr 7th, 07, 10:32 AM
BPOS BPOS is online now
Al
If you car originally came with and anti-dieseling solenoid (or whatever the heck that thing was) it had a nice heavy 12v "key on" wire running to it - an excellent source also. I use that wire for my ignition
69 PJ Convert, RS added, 383, Pro-Filer 195s, 2004R, 3.73 posi 8.5, C6/LS1 Brakes, etc "Big hitter, The Lama....long." Carl Spackler
Old Apr 7th, 07, 11:03 AM
CFunK CFunK is offline
Call me Funk
I did what Jim did, used the coil.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Where to hook up power for electric choke?
Location
Location
First Name
Human Verification
Similar Threads
Holley choke adjustment? Spiked67 Engine 3 Dec 15th, 05 08:58 AM
12V power for gauges 68driver Electrical & Wiring 6 Aug 28th, 05 03:09 PM
Quadrajet Choke Issue Silver69Camaro Engine 9 Jan 26th, 04 08:56 AM
Qjet choke problem/question BC Engine 16 Aug 28th, 01 07:58 AM
Power Steering / Belt Alignment Problem kgaffney Tech 2000 17 Jul 9th, 01 05:36 PM
