68 427 MSD runon - Team Camaro Tech
Old Apr 8th, 07, 10:34 AM
pat_c_52806 pat_c_52806 is offline
Tech Team
Default 68 427 MSD runon
Just fired up for the 427 first time in the car. When the ignition switch is turned off it keeps running, had to pull the coil wire. Never had this problem before I replaced everything under the hood and bumper to bumper. I don't think it's the ignition switch. Am running 6al with billet dizzy.
68 SS 454 650 H.P. 600 ft.lbs.
5 spd tko 600, 4:10 moser 12 bolt, 4 disc conversion.http://community.webshots.com/user/patc52806
Old Apr 8th, 07, 10:39 AM
JimM JimM is offline
Jim
Default Re: 68 427 MSD runon
check msd.com, they have a diode kit to prevent that problem.
Old Apr 8th, 07, 08:01 PM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
Yes you have to put a diode on one of the wires from the alternator. With the motor running and alternator turning it is keeping power to your MSD box and will not let the motor turn off. Do like Jim said and go to MSD.COM. They have a troubleshooting forum on their website.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/home/pro...maro/allalbums
Old Apr 9th, 07, 12:04 PM
PROZ11's Avatar
PROZ11 PROZ11 is offline
MARK
I had that problem on my last car with MSD. Instead of the diode, I just put a heavy duty toggle switch on the main power lead for the MSD box. I hid it under the dash so it also doubled as a kind of anti-theft device.
Old Apr 9th, 07, 04:22 PM
Tech Team
Yeah I put a diode in line in the right direction and the dam thing keeps on running. I might give msd a call.
Old Apr 9th, 07, 05:01 PM
dnult dnult is online now
Sounds like your switch 12v wire (small red wire I believe) is hooked to B+ instead of IGN. However the big read wire should be connected to a fused B+ source.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Similar Threads
68 RS/SS Convertible - Baldwin 427 4-spd. Anoldindin Tag Team 5 Feb 15th, 07 02:30 PM
HEI to MSD 6AL Should I? PinMd Performance 14 Jan 15th, 06 11:20 AM
Will I get noticeable HP gain by switching from Point to MSD ray moore Performance 14 Aug 9th, 05 06:15 PM
MSD 6AL Ignition wiring problem Smokey Electrical & Wiring 6 May 2nd, 05 06:43 PM
BIg Block Info I got off the web! Very long! pdq67 Performance 6 Jan 5th, 02 02:08 PM
