power steering pump pulley removal - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old Apr 17th, 07, 05:22 PM
bob22 bob22 is offline
Default power steering pump pulley removal
trying to remove the pulley from my 70 power steering pump does anyone have any advice
Old Apr 17th, 07, 05:55 PM
KevinK7 KevinK7 is offline
Kevin
Default Re: power steering pump pulley removal
...there's a special (PS pump) puller tool (ie Here's one )
Old Apr 17th, 07, 05:57 PM
camarosrlyf camarosrlyf is offline
Tech Team
Tom
If you go to Autozone, they should have a puller in their tool loan program,
just pay the deposit and get it back when the tool is returned.
Hope this helps
Old Apr 17th, 07, 06:05 PM
Pacecarjeff Pacecarjeff is offline
Jeff
Or if the pump is off...
Just take a couple of 1X4's and hang the pump by the pulley.
Then hit the shaft till the pump falls (catch it before it lands)
Old Apr 17th, 07, 06:22 PM
zdld17 zdld17 is offline
Don
This is where I really love the key way type.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Apr 17th, 07, 06:56 PM
JIML82 JIML82 is offline
Up until 1975 the power steering pump pulley was retained on the pump driveshaft by a nut. The pulley and driveshaft had machined keyways for a 1/8 x 1/2 Woodruff key. Except for corrosion, the pulley should come straight off fairly easily when the nut is removed. If your pump has a driveshaft with a male thread and a nut on the end, this is the type of pump and pulley that you have.
Starting in 1975 both the driveshaft and pulley were changed to a press fit design. This type of pulley and shaft requires that you use special tools as described in the earlier posting. You must use the correct tool to pull the pulley from the shaft. You must also use another special tool to draw the pulley onto the shaft. If you do not use these special tools, you will destroy the pulley and probably the pump as well. This type of connection has a pump driveshaft with an internal 3/8 hex and a 3/8-16 female thread machined inside the driveshaft which you can see looking at the front of the pump.
JIML82
Old Apr 17th, 07, 07:39 PM
Jeff
OOPs.......
ignore what I said unless your pump is older than 1975.
On the old pumps my system works great - always has.
Old Apr 17th, 07, 08:03 PM
davidpozzi davidpozzi is offline
David Pozzi
The special pullers are pretty easy to find, work great. The puller has to grab the groove on the hub, not the pulley OD.
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Apr 17th, 07, 08:15 PM
Z15CAM Z15CAM is offline
Ron
75 was a h*ll year in my opinion. The Z28 and SS Camaro were gone along with all the other Muscle cars. Compression dropped to like 8:1, Sunoco 260 dried up, just look at the 75 T-Bird for example My God. Detroit just started sticking things together like power steering pump pulleys, welding on door hinges, plasticizing and attempted to sell a us performance in a package that truly sucked. No wonder enthusiasts turned to the European and Japanese Models. Man that 75 Toyota Crown which looked like an Audi or Nova depending on which direction you looked at it was Ugly but man it was built Tough and Fast It had a Full Heavy Duty frame, 15" wheels, over head inline 6 with 4 bbl and 5 spd tranny that could out perform the competition including Volvo and BMW. North American cars were not even in contention.
Here's a PIC of a 75 Toyota Crown and I believe even Richard Petty was impressed - LOL
http://www.cars-directory.net/galler...1203771_p.html
This 77 4 Dr looks almost identical to a 77 Chevelle with a Dart Front end ))
http://www.cars-directory.net/galler...2242770_p.html
No offense I'm just having FUN ))
Z15CAM - There was a Viper in my Rear View
This was my 70 1/2 Z28
http://www.flickr.com/photos/28082975@N04
Old Apr 18th, 07, 06:24 AM
I don't know why, but the assembly plants always had problems assembling the Woodruff key and then torquing the nut to make the connection of the pulley to the power steering pump. When the interference fit pulley and pump was introduced in 1975, power steering warranty improved.
This same interference fit connection (pulley to power steering pump) is still used on all Saginaw pumps today (30+ years later).
JIML82
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: power steering pump pulley removal
Location
Location
First Name
Human Verification
Similar Threads
67 Camaro Power steering gear box pdq67 Brakes, Suspension & Steering 5 Nov 8th, 14 09:14 AM
68 BBC Power Steering Pump cjuetten Brakes, Suspension & Steering 5 Jun 29th, 06 08:39 PM
Power Steering Pump Pulley Removal icedog75 Engine 8 Dec 27th, 05 05:32 PM
Power Steering Bracket to Water Pump?? Andrew69 Brakes, Suspension & Steering 2 Oct 2nd, 05 06:29 PM
power steering noise with new (reman.) pump kennys Brakes, Suspension & Steering 4 Sep 18th, 05 08:47 PM
