Stainless window weatherstrip channel - Team Camaro Tech
Body Shop Paint & Body Forum
Old Nov 25th, 00, 12:40 PM
gheatly gheatly is offline
Gene
Post
After many months in the body shop, my car is finally coming back together. My question relates to the stainless window channel that the window weatherstripping fits into.
What sealer should I used when I reinstall the channel? The original sealer looks like it was a sponge like material, but with a tar-like material added in. There was also some white to light tan sealer on them as well.
Any hints where to pick this stuff up?
Pearl blue & white 69 Camaro with supercharged 350, Tremec TKO, and 3.73 12-bolt
See my website updated 9/01/00 at:
www.geocities.com/gheatly
Old Nov 25th, 00, 02:36 PM
gab7584 gab7584 is offline
Tech Team
Lightbulb
If you are talking about the moulding below the roof drip moulding then you could use 3M brand automotive bedding and glazing coumpound part number 08509 black in color, it will always stay semi soft or if you want the tan color you could use an all around body sealant ( 08500 is white ) I don't know the number for tan, but it should say on the tube. Carquest or NAPA or what ever auto parts warehouse should stock this stuff.
Old Nov 25th, 00, 05:35 PM
Gene
Post
gab, you are correct. I am talking about the molding directly beneath the drip rail. Thanks for the info. The original tan stuff has hardened slightly, but it still kind of soft.
The sponge/tar stuff in a pain in the butt to clean off, but so far, WD-40 seems to be doing the trick.
Old Nov 26th, 00, 06:09 AM
ragtopman ragtopman is offline
Jim
Post
Try some 3m 'strip caulk'(its also called dum dum). Id stay away from the 3m 8509, that stuff was made for filling up the gap between the windshield(or back glass)and the car on the bottom so water doesnt sit down there and rot the pinchweld out.
67 Camaro SS Conv.
70 Challenger R/T Conv.
Old Nov 27th, 00, 01:18 PM
Kevin Kevin is offline
Post
I used some black thick (1/16") 3M 3/4" double-sided tape available at body shops when I did mine. It sealed very well and wasn't messy at all.
Old Nov 28th, 00, 08:20 AM
Gene
Post
Kevin,
It sounds like that product would be better than laying a strip of sealing putty. I was concerned about warping the channel because the putty can be hard to press into place. Do you have any more details on the product you used. Thanks.
Old Nov 28th, 00, 12:44 PM
allcamaro allcamaro is offline
Joel
Post
The only reason the sealer is their is to keep water from comming back into the car from under the stainless.The stainless is attached by screws so the sealer dosent really matter as long as it stays soft but not runney when the summer months come back.
Old Nov 30th, 00, 04:02 PM
CarlC CarlC is offline
Post
Gene,
I cheaped out when I did mine but found a reasonable solution.
Home Depot sells a grey strip putty that is used to seal seams around windows. It comes in an approx 3/4 wide strip with 1/8" lengthwise serations so that you can peel off a 1/8" bead. Lay it on and press it down (or up) by hand. It will not permanently stick. You can find it in the strip foam section and costs about $4. The sealer also works great for sealing the kick panels.
MEK does a pretty good job of getting off the old oil-foam but is very aggressive on your skin.
Carl
Click here to see see my car and hear 5-speeds. http://www.geocities.com/casanoc
Old Jan 8th, 09, 12:16 PM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
Default Re: Stainless window weatherstrip channel
Thanks for the info in this thread!
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
Old Jan 9th, 09, 08:57 AM
Musclerodz Musclerodz is offline
3M strip caulk would is what I use.
Mike Redpath
Musclerodz & Customz
405-735-8405
pro-touring parts specialists
www.musclerodz.com
facebook page
http://www.facebook.com/#!/pages/Mus...73054649402015
