Pro Touring Todays performance with classic style
Old Apr 22nd, 07, 12:01 PM
jeffhansen@charter.net jeffhansen@charter.net is offline
Jeff
Default 8-71 or Ram Jet
I am completing my 69 camaro and wanted to requet you opinion on the engine induction. The car has 20 x 16 Boyds in back with the huge MT radials, matching Boyd 18's on front. Wicked paint and a very nice interior with a high end roll cage that fits perfect. It will have a big block in it and cannot decide between the chrome 8-71 blower with carbs and BDS scoop, or a factory Ram Jet system. The car has chome tubular a arms and painted chassis and 9" housing. I have a 2" and 4" hood. Appreciate your suggestion.
Old Apr 22nd, 07, 12:10 PM
camcojb camcojb is offline
Jody
Default Re: 8-71 or Ram Jet
the 8-71 won't fit under either hood, so for stealth the RamJet gets the nod. Plus visibility is limited with the 8-71, so for a pro tour car it really doesn't fit the theme.
However it's your car and the blower definitely stands out, plus the obvious power difference. The engine build will be completely different for the two, so hopefully your engine is not built yet. If it is give the specs.
Jody
new updated website!
64 Chevelle twin turbo LS2
Old Apr 22nd, 07, 01:21 PM
V-12-Camaro V-12-Camaro is offline
Tech Team
Pro-touring?????
More like ultra pro-street. That's a good thing though. It seems like pro-street has gone into submission again, in favor of pro-touring. Not that that's a bad thing either (soon I'll have one of each).
I have a stock-bodied 1966 Biscayne. I didn't hack anything on the entire build, but it took everything I had to drill a few holes in the trunk pan to run the fuel lines. Like the old saying, it truely can be put back to stock. That will never happen.
It has the usual stuff for a pro-streeter. Weld wheels, nice paint and a nice drive train package. I can honestly say that what sets the car off is the 671 sticking out of the hood, well, if it had a hood (I wasn't about to chop it up). It's the classic example of the engine making the car what it is. It wouldn't make for a good drag car, that's not its intentions. I built it as a cruiser (stock block 406, stock rods/crank, good parts/good machine work) and it does that really well. It's honestly my first project. I did all the wrenching, welding, and fabricating. It's far from perfect and still needs completing (I'm concentrating on my Camaro project now). It runs and drives like it is, so that's kind of how I left it. Many years ago I converted it to DFI and couldn't resist the look of a bug catcher.
http://themagicm.homelinux.org/phpga...92/category/38
So for my advice and to carry your car's theme onto the engine? I'd go w/the blower. If it's attention that you want, it'll surely get it. There's nothing else like it. Keeping everything under the hood just wouldn't be the same.
Old Apr 23rd, 07, 07:39 AM
PROZ11's Avatar
PROZ11 PROZ11 is offline
MARK
Hey Jeff,
I 'm a blower guy all the way. Although, I do agree with camcojb that an 871 doesn't reall "fit" the Pro-Touring theme. Maybe an under hood set up, like a Procharger might be a better choice.
Now, I'm not telling you not to do the 871. I've had big "huffers" sticking out of the hood of my last to cars. Although, the were both Pro Street cars, like my Camaro. Which is in the final stages of the build.
Nothing gets the attention and crowd draw of a blown Big Block. Not bad for gobs of power either. I say, if you do go for the blower, you won't ever regret it.
If you want a visual of the blown big block look on a first generation Camaro here's a shot of my car:
Pro Street Z11 clone
http://img183.imageshack.us/img183/8...mart010ce4.jpg
Old Apr 23rd, 07, 08:07 AM
softail02 softail02 is offline
Keith
Polished... you do not want a chrome blower
70 RS Pro-Street
69 RS/SS wifes car
07 Tahoe LTZ
02 2500 crew LT Duramax
04 Fatboy
www.racealley.com
Old Apr 23rd, 07, 08:55 AM
PROZ11's Avatar
MARK
Oh yea, I was gonna make that same point as softail02. You want a polished blower, not a chromed one.
Old Apr 25th, 07, 06:22 PM
BelAirBob BelAirBob is offline
Bob
I say polished, blown and slammed....
BelAir Bob
67 RS 327, PG matching #s.-being resto'd.
69 Z28/RS X33 D80 Dusk Blue DZ,M21,Endura, Fiber optics- being resto'd.
67 327/275 L30, PG All matching w/broadcast sheet- Fact AC,PB,PS- Being enjoyed
http://www.belairbobs.com
Old Apr 25th, 07, 08:56 PM
Jeff
Thank you for the suggestions to all. Bob, is the blower on your car seems to stick out just right, any spacer or intercooler? How do you post a picture on here, I have a 6 second pro mod 69, and I wanted to post pictures of the car I need to decide on the blower or ram jet. The 20" Boyds make the thing look very modern. Thank you
Old Apr 26th, 07, 03:40 AM
Bob
No intercooler, but it was a 14:71 blower, not the smaller 8:71. Intercooler raises an 8:71 about 3 inches,so roughly the height of a 14:71.
BelAir Bob
Old Apr 26th, 07, 03:19 PM
Rich-Allen Rich-Allen is offline
Bob, That's one Sick car !!
AFR Heads W/ Jesel valve train
http://www.fquick.com/Rich-Allen
67 RS / SS
http://eastbayerectors.com/camaro.html
Old Apr 26th, 07, 05:07 PM
Bob
Yeah... It even had AC, power windows,tilt,digital dash and LED turn signals built into the grille. I miss it, but what could you do with 900 HP on pump gas anyway?
BelAir Bob
Old Apr 27th, 07, 07:59 AM
Jeff
Sounds like it was a driver, how did you address the heat and what fan set up did you have?
Old Apr 27th, 07, 08:17 AM
Bob
Heat was never an issue. It was a 540 BB. On a blown engine, you need to keep the timing and boost right. Mine never needed more than 6 psi to make serious torque and HP.This was driven 1:1. The bigger the engine, the faster you need to spin the blower. Timing was 36 degrees total. (Blowers like more timing). Radiator was a custom built aluminum unit by C&R racing. I also built some side baffles in order to direct more air through the radiator. Fan was a large single puller config,which ran at 2700 RPMs. I also used "water wetter" in the water as a precaution. The car never ran over 210 at any time,averaging about 180 degrees in the summer. I had concerns over heat as well,but was pleasantly surprised by the results.
BelAir Bob
Old Apr 27th, 07, 08:27 AM
PROZ11's Avatar
MARK
Hey BelAirBob,
Forget about how cool it ran. How cool did it sound with that exhaust? Must have been pretty crazy. My blown BB (tiny compaired to yours, only 427cuin) is loud with a full exhaust. That had to sound awesome! Any video of that car? Any more pictures? That thing is over the top.
Mark
PROZ11
PS: I also run mine at 36 degrees total timing on my 671. But mine is over driven 12%.
Old Apr 27th, 07, 10:05 AM
Bob
LOL... Yep LOUD is an understatement. With those short pipes which had baffles in them (basically open exhaust), it would rattle China cabinets for two blocks! Here are some more pics...
BelAir Bob
Similar Threads
502 Ram Jet tobin67 Engine 10 Dec 11th, 07 11:38 PM
accel super ram vs. holley stealth ram Skeletor Performance 5 Mar 6th, 06 06:34 PM
Holley Stealth Ram Clearance Ryan Windham Performance 2 Jan 22nd, 06 09:14 AM
bbc tunnel ram top same as SBC tunnel ram top? 67stang Engine 1 Nov 22nd, 05 07:28 PM
ZZ502 Ram Jet questions DirtyScotty Engine 2 Oct 26th, 05 06:45 PM
