Pro Touring Todays performance with classic style
Old Apr 24th, 07, 10:43 PM
diamond diamond is offline
Matt
Default Front Tire Clearance
What is the biggest problem with front tire inside clearance when lowering (let's say 2") a 1st gen Camaro and using a wider tire? Will the tire hit the frame when turning the wheels before there is any problem with the wheel housing? Obviously offset has a lot to do with it. I would think that the biggest issue with the outside clearance would be the fender lip. Any feedback from anyone with experience with these issues would be greatly appreciated!
Similar Threads
Trimming rear fender for tire clearance... ratbikeharley Body Shop 3 Aug 2nd, 06 09:20 AM
Suspension Parts List davidpozzi Brakes, Suspension & Steering 3 Feb 23rd, 04 02:54 AM
FRONT TIRE RECOMMENDATION? camaro man Wheels & Tires 4 May 29th, 03 04:05 AM
need front tire size with Gulstrand ochrisl Brakes, Suspension & Steering 9 May 28th, 03 12:04 PM
dual exhaust ground clearance and tire size Scrappy Doo Tech 2000 5 Nov 10th, 00 09:04 PM
