Pro Touring Todays performance with classic style
Old Apr 30th, 07, 09:01 PM
Qwank Qwank is offline
Tech Team
Default T56 questions
hey everyone. i got a couple of quick question. i work at a chevy dealer and i like to pick parts out of the scrap pile that i can rebuild/reuse. two of the things i have collected are 2 t56 transmissions. i have one from a 2001 trans am that was replaced because the owner ran over a rock and cracked the case and bell housing. and i have one out of a 96 z28 that was replaced because it was popping out of 3rd gear. needs those plastic bushings that always break and has a questionable 3rd gear and syncro. so my plan is to take the case from the 96 and put the guts from the 2000 in it.
i just want to verify that the front part of the housing is differnt for the LT1 and LS1 models. if it is i can get the front housing and bell housing for around $400 for the pair at work. i have the LT1 housing but i'm planing on mating the tranny to an LS6 that i pulled from the scrap pile also. (Needs a piston) thanks.
Old Apr 30th, 07, 09:26 PM
JimM JimM is offline
Jim
Default Re: T56 questions
try this: http://www.camaros.net/forums/showthread.php?t=98387
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old Apr 30th, 07, 09:32 PM
Tech Team
thanks for the link!
Old May 1st, 07, 05:05 PM
Tech Team
ok i read that and today at work i had the parts guy check the LS1 cases against the LT1 cases. the only peice that is the same is the center piece. which is also the most expensive so thats ok. the tailshaft housing and the front adapter are both different. but from reading that thread it looks like i can just put the LS1 input shaft in the LT1 shaft and use a Ls1 belhousing to bolt it up?
Old May 1st, 07, 05:22 PM
Jim
that's what I read, tho it was a while ago. Also I seem to recall that the LT1 and LS1 input shafts are different lengths. Coiuld be wrong tho, it's been months since I read that post.
Mike did a great job filling in a lot of blanks.
Jim's NEW Blog!
Jim Cam
Old May 1st, 07, 05:44 PM
Tech Team
i think i'm going to read it again
Old May 1st, 07, 07:56 PM
Rodder's Avatar
Rodder Rodder is offline
Team Member
Jon
You'd have better luck asking in the Transmissions forum on LS1tech.com...
1968 Camaro Convertible - LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Old May 2nd, 07, 11:03 AM
Tech Team
oh yeah i forgot about that forum. i need to find my user name and password though
Old May 2nd, 07, 11:48 AM
Mkelcy Mkelcy is offline
Mike
The main case should be the same for both the LT1 and LS1 T56's. As you point out, the tail shaft housing and the front "intermediate" plates are different. You should be able to use the LT1 main case with the LS1 guts, tail shaft and front "intermediate" plate. LS1 T56 bellhousings go for about $150 on Ebay.
Mike - 68 Camaro with some stuff done to it; building another '68 with even more stuff done to it.
http://www.camaros.net/forums/attach...2&d=1176782254
Old May 2nd, 07, 05:25 PM
Tech Team
well my intermediate plate and tailshaft housing are cracked also. will the input shaft from the LS1 fit in the LT1. and will a LS1 bellhousing bolt up to a LT1 intermediate plate?
Old May 2nd, 07, 05:45 PM
Teetoe_Jones Teetoe_Jones is offline
The shaft will fit inside the case, but it is 3/8" longer than an LT1. The LS1 bell will not bolt up to an LT1 front plate.
Tyler
Old May 2nd, 07, 07:03 PM
Tech Team
thanks
Old May 3rd, 07, 08:44 PM
Tech Team
well i looked at the cracked tranny today and brought it down to a welder and the bellhousing and intermediate plate are repairable since they are very minor cracks. so everything should work out with very minimal part replacing.
Similar Threads
T56 Information - First Generation Camaro Swap Mkelcy Transmission & Driveline 139 Aug 4th, 09 07:49 AM
'69 SS396 - 2000 T56 Install SKIPS69 Transmission & Driveline 8 May 6th, 07 02:18 PM
5 speed or 6 speed?? 69Thrasher Transmission & Driveline 22 May 29th, 06 09:57 PM
Questions about BBC combo for my car. Dominate67 Performance 13 Sep 14th, 05 08:41 AM
700R4 converter questions z/27 camaro Transmission & Driveline 9 Feb 11th, 04 07:45 AM
