Front coil spring spacers - Team Camaro Tech
Old May 1st, 07, 08:26 AM
BPOS BPOS is offline
Al
Default Front coil spring spacers
Let's just say, hypothetically of course, that a guy put Hotchkis lowering springs in the front of his car, and now it sits so low that his headers scrape when he backs out of the driveway. Would he be able to buy a spacer that sits on the lower A-arm to raise the front end of the car about an inch and still keep the same (or close to it) spring rate? Purely hypothetical of couse, but a guy I know VERYwell might be in this predicament as soon as he gets his car down off the jackstands.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old May 1st, 07, 09:23 AM
Everett#2390's Avatar
<Jake 68's Rule
Default Re: Front coil spring spacers
Certainly wouldn't hurt. You might go for the rubber insert between the coils.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old May 1st, 07, 09:36 AM
JimM JimM is offline
Jim
Comp Engineering makes a wide variety of coil spring spacers
Old May 1st, 07, 10:24 AM
Codi's Avatar
Codi Codi is offline
Jim
You can use the insert that is maketed as a noise supressor. The entire spring seats into it.
Daddy's Hot Rod.
http://www.camaros.net/showroom/show...e=365&way=desc
Old May 1st, 07, 10:27 AM
Al
Thanks, guys. Any links? Jim - I searched competition Engineering's website and couldn't find them.
Codi - who makes the animal you speak of? Thanks again.
Old May 1st, 07, 10:38 AM
Jim
ok well, I'm irritated, I hate it when I misremember stuff. When I was putting my suspension together someone sent me a link, cause I had one side higher then the other.
I went thru all the posts, can't find it. Sorry Al.
Old May 1st, 07, 10:54 AM
zdld17 zdld17 is offline
Don
Parts stores carry the solid hard rubber flexable spacer to lay on coil. tape them to the top of the coil and insert, dont miss the spring pocket upstairs. 5/8 or 9/16 should do it. Dont put those twist in jobs. Easybutton. Safe to have front end alignment checked again.
http://www.competitionengineering.com/default.asp
Yea Jim, and you are much younger than I am. Wait a few more years.
Try this too. http://www.mr-gasket.com/SearchResults.aspx?brandId=1
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old May 1st, 07, 11:32 AM
Jim
the link I had had hundreds... different heights, different ID's and OD's even different pocket shapes.... don't know where it went tho.
Old May 1st, 07, 02:10 PM
Eric Kammerer Eric Kammerer is offline
I don't know if it's the link/site you're thinking of, but Global West carries aluminum spacers for under the coil, like Al was thinking. I got a pair of 0.5 inch in case I need them.
Eric
69 'vert project big block/TKO 600 RR
68 'vert driver RS clone -- gone!
Old May 2nd, 07, 01:13 PM
Al
Hey Jim - I think I found it! You must have meant Energy Suspension insted of Competition Engineering.
http://www.energysuspensionparts.com...-Isolators.asp
Anyway, I let it down off the stands for a look see and HOLY CRAP it's low! Too low for my tastes, and too low for my header's tastes as well. It needs to go up at least an inch. Thanks for the help guys, and wish me luck.
Al
Old May 2nd, 07, 01:17 PM
I asked a similar question a while back, and Chris (CFunk) pointed me to the GW spacers. You can find a picture and info at the link in his sig.
http://www.camaros.net/forums/showth...ghlight=spacer
Eric
Old May 2nd, 07, 01:41 PM
Jim
YES! Energy suspension, that it! I knew there was an E in it!!
Old May 3rd, 07, 09:35 AM
Al
Thanks for the link, Eric. I ordered the GW spacers.
Old May 3rd, 07, 09:43 AM
Codi's Avatar
Jim
Don got it for me, a full spacer. As for Jim, to much time with the "grains" liquid and hot tub.
Daddy's Hot Rod.
Old May 3rd, 07, 05:18 PM
I'm hoping to not have to use mine, but they are cheap enough that it's just nice to have them as an option.
Eric
Similar Threads
Front Spring Eye Location VS. IC ron498 Performance 2 Oct 5th, 05 08:19 AM
Landrum spring adjusters jmar Brakes, Suspension & Steering 14 Jul 18th, 02 05:36 PM
Wrapping front leaf spring eye David R Brakes, Suspension & Steering 2 May 3rd, 02 08:21 AM
Front Coil Spring removal? Inferno Tech 2000 8 Jul 9th, 01 05:00 PM
Front coil spring swap w/ from 78Z to 68 S_Snitily Tech 2000 1 May 5th, 01 09:08 AM
