EFI in your modern Classic EFI conversions in FirstGen Camaros
Old May 1st, 07, 08:56 PM
Rodder's Avatar
Rodder Rodder is offline
Team Member
Jon
Default Post your EFI Conversion here
'68 Camaro Convertible with a '99 Camaro SS LS1/T56.
Website: http://www.blown.net/camaro68.html
Build Pictures: http://www.blown.net/ls1swap/
Build Blog: http://www.blown.net/ls1swap/blog.html
ATS T56 install kit (crossmember and hydraulics)
Autokraft (ATS clone) mounts
Autokraft oil pan
Covan's gauge panel
Autometer UltraLite-II full sweep electric gauges
Lokar LS1/RamJet throttle cable
Energy Suspension engine and trans mounts
69 Camaro 6-cyl gas pedal
'06 Z06 clutch/flywheel
Driveline Solutions 9-inch rear with TrueTrac diff
Wilwood street rear discs
AGR 12:1 steering box
Hydratech hydroboost brake booster
Rock Valley stainless fuel tank with LS1 pump
'99 Corvette fuel filter/regulator
Hooker SuperComp LS1/firstgen swap headers
HPTuners VCMSuite software
AEM air filter
Procar Elite seats
Hurst Billet/Plus shifter
1968 Camaro Convertible - LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Old May 1st, 07, 11:56 PM
Fred Ficarra Fred Ficarra is offline
Fred
Default Re: Post your EFI Conversion here
Fun! Ok, here's my stuff;
Old, original, pre 69 Camaro engine, old.
L88 bought in 1968. Car bought in 1969. L78 finally broke in 1974. Installed L88 after updating it to open chamber and LS7 rods with boron bolts and true-locks and off-road aluminum heads.
After living with various carbs for another 20 years or so, Holley came out with Projection4. Bought it. It worked OK but still had 'consistency' problems. This winter we pulled the engine and freshened-up stuff. But not the FI. Now it's very strong and consistent. We have yet to find a MPH that the engine CAN'T smoke the tires by punching it. (faster that 60 hasn't been done yet because of traffic) As far as consistency, I suspect the intake manifold seal. It's working great now.
The car hasn't been seriously raced since 1970. Tomorrow the DOT slicks, skinny front tires and wheels arrive. The 90/10 shocks came today and are installed. The rest is on my web site. The first race is Saturday, baring rain.
It's not my second childhood, the mortgage is PAID-OFF!
One owner 69 Camaro,(yep, bought it new) RS SS Hugger Orange, L88, 4:10 posi, ducted hood and best et 11.59, 1.5's 60'. All with 1960's stuff. (except tires and converter)+ MT Super Scavenger headers. OK FI too.
http://epitomesrebuild.com/
Old May 2nd, 07, 07:03 AM
Silver69Camaro Silver69Camaro is offline
Matt Jones
Here we go:
2001 LS1 w/T56 (completely stock)
4" Mandrel-bent intake tube
1-3/4" Full-length AME Headers
Pro 5.0 Shifter
Centerforce clutch
Art Morrison Subframe using Corvette components
AGR 15:1 Steering Rack
Wilwood 14"/13" 6/4 Piston Brakes
Wilwood balance bar pedal assembly w/ individual masters
Rock Valley modified OEM tank
Vette Filter/Regulator
Speartech programming
Lokar throttle cable w/ custom pedal assembly (to match the Wilwood pedals)
Autometer gauges
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Old May 2nd, 07, 07:28 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Team Member
Scott
Jim; Sticky this, and delete my thread. Please!
Old May 2nd, 07, 07:34 AM
JimM JimM is offline
Jim
Finished your blog this morning Jon, great stuff. Was hoping you'd have stuff to add here!
Scott, we'll see about sticky's, no need yet. your thread stays.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old May 2nd, 07, 02:11 PM
sc68z28's Avatar
sc68z28 sc68z28 is offline
Gold Member
"Stick Willy"
EFI section Great addition for the site.
Here's my hodge/podge of parts.
Gen 1 383 SBC
Vic jr converted to EFI by Wilson manifolds
72# RC Injectors
Rick's stainless tank, w/ Aeromotive Eliminator pump inside
Accufab 1230cfm throttle body
MSD billit dual sync distributor, for cam and crank refference
FAST XFI controller running in sequential mode
Aeromotive boost refference regulator, set at 45# base presure
130 amp MSD alternator, need lots of power to run all this stuff
2 bar GM map sensor
This combo has worked well for me, up to 17# of boost, at that point it's seeing about 90% injector duty cycle.
---Bill.
1968 w/ Procharged 383, FAST EFI, G-force 5R trans, 7" two disc clutch,
9.28 @141 vid http://www.youtube.com/watch?v=rF7_XaL2jSU
Best 60' 1.32 vid http://www.youtube.com/watch?v=x3UZW6smFtw
http://www.chevyhiperformance.com/fe...z28/index.html
Old May 2nd, 07, 03:03 PM
camcojb camcojb is offline
Jody
Here's a few I've done.
Jody
new updated website!
64 Chevelle twin turbo LS2
Old May 2nd, 07, 04:28 PM
sc68z28's Avatar
Gold Member
"Stick Willy"
Jody
Your work allways looks so nice
---Bill.
Old May 2nd, 07, 05:43 PM
Jody
---Bill.
thanks Bill, much appreciated!
Jody
Old May 2nd, 07, 06:28 PM
pro70z28 pro70z28 is offline
gary
BBC w/1071 stage 3 BDS blower with an Enderle Bug catcher & Hilborn EFI fuel rail. Sold it to go with a front mount f2 in an attempt to keep it all under the hood. Engine is lowered and I have a 3" cowl hood scoop.
Old May 3rd, 07, 09:49 PM
Nine Ball Nine Ball is offline
Tech Team
Previous Project:
69 Camaro SS
348ci LS6 w/ Magnacharger (505 rwhp)
T56 6-speed
Factory 98 Camaro PCM, Painless harness
BRP subframe and engine mounts, steering rack/pinion
Sumped factory fuel tank, external fuel pump and regulator
Stainless Works longtube headers
factory unmodified oil pan from 98 Camaro
10.7 ET 1/4-mile times
Website: www.ExtremeG.net
Current Projects:
1969 Camaro SS convertible, building 427ci LS7 + T56
1967 Camaro, forged 347ci LS1 w/ D1SC Procharger
Tony
Co-Founder, www.LS1TECH.com
68 Camaro RS convertible
69 Camaro coupe
70 Chevelle SS 454
02 Formula Firehawk
06 GTO
06 Viper coupe
Online Garage: www.fquick.com/NineBall
Old May 3rd, 07, 10:34 PM
Mark .L.W. Mark .L.W. is offline
My system is a holley comander 950 with the wideband o2 , this coming winter i will be adding a ATI procharger F-1 with air to air to my 427 sbc , I'm sure it will work just fine after all the help from Jody and others .
69 camaro convertible
427sbc with cnc'd track 1's
sollid roller with rev kit .
TKO-600 with Mcleod dual disc .
pictures can be viewed at http://photobucket.com/albums/b247/mark69rs/
Old May 12th, 07, 12:44 PM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
Team Member
Jan
Here is what I have been up to lately.
It is a LS1/T56 out of a '02 Camaro SS that I have put in my '69 Z/28. Before this conversion I had done the Protouring treatment on the car with C4 brakes and Hotchkis TVS and the Guldstrand Mod.
Expect a lot from this new drivetrain and it will be tuned in hte future. Only modification now is the 1 3/4" headers that will require a tune of the fuelcurves.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z-28, Cortez Silver, LS1 / T56
protouring.se
Old May 24th, 07, 07:25 PM
V-12-Camaro V-12-Camaro is offline
Tech Team
I converted an old bug catcher to DFI, it sits on top of a 6-71 blower.
I pieced the system together myself and got the electronics from Blower Drive Service. They will gladly sell any part that you ask for, but technical services are really crappy.
They claim that it's a plug-n-play system. It can't be farther from the truth. Craig (he showed up on Monster Garage when they built a blown Caddy-Craig's tuning was far from perfect on that one too) is head of the tech department, he was no help at all. I sent the ECM back for programming a second time, the car wouldn't even run. It would start and die w/no attempt to even idle.
To make a longer story shorter, I wiped out all of BDS's programming and tuned the thing myself.
I give it a few tweeks every time I drive the thing. It's slowly getting closer to perfection.
Old May 26th, 07, 08:07 PM
TazJr800 TazJr800 is offline
1967 Camaro SS 396
Mike
60'- 1.687
1/8 mile- 7.415 @ 93.49 MPH
1/4 mile- 11.608 @ 121.43 MPH
Pictures here... http://mysite.verizon.net/resudxhw/
Similar Threads
First post!!! New 1969 Camaro owner Trakspeed Camaro Tech 6 Jan 21st, 06 07:36 AM
