EFI in your modern Classic EFI conversions in FirstGen Camaros
Old May 2nd, 07, 10:11 AM
paulm paulm is offline
Paul
Default LT1 Intake Swap
There are many options for adding EFI to you camaro, but one option that caught my eye a while back was using an LT1 intake.
I could have bought an aftermarket intake but at the time it seemed a little pricey so I went down to the local bone yard and found a complete intake off a 96 firebird for a hundred bucks. This included the intake, fuel rails, pressure regulator, injectors, throttle body, MAP, IAC and TPS. To make this fit on my 383, it had to be modified. It just so happens that there is a guy that modifies them to fit an old school SB for two hundred bucks, so I sent it off. He drilled the hole for the distributor, modified the bolt pattern and ground off the EGR bosses to make room for the distributor. You can do this yourself, but I didn't feel capable and didn't have the desire.
My rational for using an LT1 intake was that I am personally comfortable working on/rebuilding old school SB's. They are cheap, easy to find and I felt more comfortable with having less variables in converting to EFI. I knew that the engine would drop in and most everything would just "bolt up". All I had to do was make accomodations for the intake change and EFI setup.
After I got the intake back it was ready to just bolt on with regular intake gaskets. An LT1 intake does not have T-Stat accomodations on the front, so holes were drilled and tapped on the back of the intake so that 3/4 hose nipples could be screwed in. I used ninety degree fittings on the back and ninety degree hoses to try and make the coolant hose routing look a little cleaner. The hoses then route from the back of the intake around the drivers side valve cover and to a remote T-Stat housing. I had to make a bracket to mount the T-Stat housing to the head.
With the coolant hoses routed, the next thing that I had to deal with was mounting the alternator and power steering pump. Since the LT1 intake has no provisions to bolt first gen camaro brackets to I had to buy brackets from Alan Grove to get the alternator and PS pump out of the way.
With that, the intake was installed! Next up was connecting the throttle linkage, so I picked up a six cylinder pedal and a throttle cable from a 95 impala...Done! I am running a 2004R, so I needed a TV cable, 93 camaro cable worked perfectly.
In any EFI setup, the fuel system needs to change from stock. I bought an in pump tank from Rock Valley, had Right Stuff Detailing bend me up two stock 3/8 steel fuel lines with extra length on the front and back and bought some LT1 conversion lines from Street and Performance. After that I used some compression fittings to connect the braided steel to the hard lines and I had fuel from tank to intake!
Next I needed a distributor. I figured that I would let the computer control the timing so I had a local shop build me a small body GM HEI. I just had to make a little bracket to mount the coil to the firewall.
To run closed loop as with any EFI setup I also had to weld in the bung for the O2 sensor into the exhaust.
I also needed an air cleaner, Street and Performace makes one with a built in port for the MAT sensor.
OK so now I have all of the hardware in place, the last step is the wiring harness and ECU. I had a Holley 950 Commander ECU from running TBI injection on my 69 ragtop, so I used that. I just had to change the harness. I bought the right connectors from Ebay, spliced everything in I had wiring! I mounted the ECU on the firewall, just made up some brackets and welded them to the back of the heater delete plate that I made. You could use a GM computer/harness and have it reprogrammed, but I like being able to connect my laptop and change the settings whenever I want.
So that's basically it, after that it's all just tuning the fuel and spark maps with my laptop. Using an LT1 intake may not be for everyone. It doesn't look as clean as some of the aftermarket intakes because of the mods to the intake and the coolant hose routing (see pics in my signature), but it works for me as I am kind of a redneck anyway!
Parts required:
Modified LT1 intake
Fuel rails
Fuel pressure regulator
Injectors
Throttle Body
TPS (Throttle Position Sensor)
IAC (Idle Air Control Valve)
MAP (Manifold Absolute Pressure Sensor)
MAT (Manifold Air Temp Sensor)
CTS (Coolant Temp Sensor)
O2 Sensor
ECU
Wiring Harness
Fuel supply and return lines
Electric fuel pump (either internal or external)
conversion lines to connect to LT1 fuel rail
Aftermarket Alternator and PS brackets
Remote T-Stat housing
Throttle cable and pedal
Various heater hoses, connectors, wiring, etc
Resources:
http://www.lt1intake.com
http://www.hotrodlane.cc
http://www.alangrovecomponents.com
http://www.rockvalleyantiqueautoparts.com
http://www.holley.com
http://www.rightstuffdetailing.com
My 67 HSR Intaked RS Coupe
Best of 1.56 - 11.69@112.95
Old May 2nd, 07, 10:21 AM
JimM JimM is offline
Jim
Default Re: LT1 Intake Swap
Fantastic, Paul! Why is this the first we're hearing of you lil "franken-jection"?
I've had a couple LT1 vette's, and have always loved the look and performance of that manifold. Marrying it to a holley controller is right up my alley, too.
I've been leaning toward a holley TBI due to general cheapness, but this could fit my plans real well.
Exactly what did you use for an air filter? Is it one of thier street rod shorties, or something more?
We need pics!!
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old May 2nd, 07, 10:28 AM
Paul
"franken-jection", LOL!!!
S&P, sells an LT1 air cleaner that fits right on.
Here are some pictures:
http://www.stratagaz.com/67L30M35RS/...RSEngine01.jpg
http://www.stratagaz.com/67L30M35RS/...RSEngine02.jpg
http://www.stratagaz.com/67L30M35RS/...RSEngine03.jpg
Old May 2nd, 07, 10:31 AM
lortsie's Avatar
lortsie lortsie is offline
Adam
Click on his 2nd link in his sig
Looks great man, good work! Cool to see an LT1 intake with an HEI distributor lol
67 RS/SS "YELR67"
Old May 2nd, 07, 12:11 PM
bearcat44 bearcat44 is offline
David
Hey can I get a pm on how much all that cost ya? Looks great to me as I'm just about as hickish!
the learning curve is....expensive
Old May 2nd, 07, 12:34 PM
Paul
Sheesh, you're going to make me add this up!!
EFI Stuff:
LT1 Intake $100
Conversion $200
Holley ECU, wiring & sensors $400 (I think, could save money here on GM stuff)
Air cleaner $125 (S&P)
Rought total of EFI Stuff $825
Ignition:
GM Small body HEI, Cap, Rotor & Coil $200, roughly
Rough total of Ignition $200
Misc:
Alan Grove Brackets $100 (???)
Throttle Cable & TV Cable $100 (???)
Remote T-Stat, Hose & Connectors $150 (???)
Rought total of Misc Stuff $450 (I'd add a little here for unknowns and forgottens)
Fuel Delivery:
Steel Fuel lines $50 (??? Right Stuff Detailing)
Conversion lines steel to fuel rails $100 (??? S&P)
Gas Tank $700 (??? Rock Valley)
Braided Steel lines from steel lines to tank, fuel filter & connectors $150 (??? Summit Racing)
Rough total of fuel delivery $1000
**You have to do something to deliver fuel for any EFI, I chose the expensive way. Cheaper would be an external pump.
That's my best guess as I don't have all of the invoices/receipts in front of me.
Old May 2nd, 07, 12:42 PM
David
Thanks and sorry for the extra work!
Old May 2nd, 07, 12:59 PM
Paul
The wasn't because of extra work, but because I had to add up what I spent.
Old May 2nd, 07, 01:58 PM
Jim
OH NO, you don't ever want to do that!!!
Your wife might find out!
Jim's NEW Blog!
Jim Cam
Old May 2nd, 07, 05:55 PM
Rodder's Avatar
Rodder Rodder is offline
Team Member
Jon
[quote=paulm;775514]S&P, sells an LT1 air cleaner that fits right on./quote]
Gotta love S&P's Hot Air Intakes...
1968 Camaro Convertible - LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Old May 2nd, 07, 05:59 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Team Member
Scott
LOL
Old May 2nd, 07, 07:20 PM
Paul
I could have bought or fabricated a cold air intake, but it just wasn't that high on my list. The ducting IMHO would take up too much room, I set everything up to leave the most accessibility to everything. Kind of a "meat and potatoes" install....just the basics, minimal bling.
Similar Threads
LT1 motor swap wyoming T/A Engine 0 Mar 30th, 06 06:09 PM
Which intake gasket should I use? ColoradoZ28 Engine 4 Oct 17th, 05 11:54 AM
solid lifter adjustment jks67SS396 Engine 11 Jul 11th, 05 08:40 PM
ZZ4 intake swap? choptop Performance 3 Dec 30th, 02 05:10 PM
Intake swap results - faster or not? Eric68 Performance 10 Oct 10th, 01 02:46 PM
