Dougs Headers or Thorley's - Team Camaro Tech
Thread Tools Display Modes
Old May 9th, 07, 11:51 AM
sherr20 sherr20 is offline
Jerry
Default Dougs Headers or Thorley's
I currently run Dynomax ceramic headers. The driver side hangs too low since my car sits quite low. I am looking at Dougs headers or Thorley's.
Anyone have experience with these as far as how they fit, how far they hang down, and which is better maybe?
Thanks.
67 RS/SS Butternut yellow/Blk top, 383, 9.85 to 1 comp. Edelbrock RPM, Mighty Demon 750, Dart IE ported 200's, Comp Cams XE284H, 700R4, 2800 stall, Vintage air, MOSER 12 bolt 3.73's,QA1 front coilovers, Baer Serious street kit front, Touring Classics 12" disks rear, CE Slide-a-Links, Boyd Coddington 17" Stingrays.
Old May 9th, 07, 11:55 AM
zdld17 zdld17 is offline
Don
Default Re: Dougs Headers or Thorley's
Doug Thorley , 376 y1C for manual trans cars. They tuck up very well for low clearance car. Have an exceptional sealing ability at the collector. 14 ga tubing and 3/8's flanges. Coated. Not cheap.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old May 9th, 07, 01:04 PM
Jerry
How about any info on the Doug's headers? Doug's run about 70 bucks cheaper I than Doug Thorley headers. Hell for about another $125 you can get 304 stainless from Stainless Works.
Old May 9th, 07, 02:04 PM
Mike68RS Mike68RS is offline
Mike
I'm running the ceramic Thorley 376Y's on my lowered 68 with a manual trans, excellent fit.
I ended up getting them here, cheaper than Summit Racing with 10% off and really free shipping.
http://www.autoanything.com/exhausts...0A2423262.aspx
Mike
Old May 9th, 07, 02:28 PM
BPOS BPOS is offline
Al
If you want/need 1 3/4 primary tubes, the Thorleys are out, as they don't make a SBC header in that size. Doug's D368 has 1 3/4 tubes.
What you DON'T want are Hooker SuperComp #2131. Yikes!
I recently asked a couple of members via PM about the Doug's and ground clearance - both replies were very positive.
69 PJ Convert, RS added, 383, Pro-Filer 195s, 2004R, 3.73 posi 8.5, C6/LS1 Brakes, etc "Big hitter, The Lama....long." Carl Spackler
Old May 9th, 07, 05:01 PM
TMessick TMessick is offline
T
I ended up with the Thorley 376Y1 as well ('69 coupe, ST10 manual) and bought them through AutoAnything as well after reading one of Mike's previous posts. You may need to do a search for "autoanything" and "coupon" online to find a list of coupon codes for 10% off.
As far as Dougs vs. Thorley, I believe the only 1st gen tri-y headers that are under the Dougs brand have a "375" part number, which (I'm guessing) is analogous to the "375" Thorley part. Some people have had issues with these with PS box interference, etc. All my reading here indicates that the 376Y1 or their ceramic coated equivalent are the "best fit" parts.
FWIW, here's the thread with Mike's previous post(s) and some nice header pics. (excellent car btw mike! I want your dash!)
http://www.camaros.net/forums/showth...=102486&page=3
Old May 9th, 07, 05:35 PM
Don
I will vouch for the Hooker 2131, They are good headers but they hang too low. What I got rid of.
Don
TC # 349
Old May 9th, 07, 06:09 PM
dnult dnult is offline
I have Thorely 376Y1C on a 68 SBC w/ a THM700R4 Automatic. I noticed folks saying they work with a manual box. They also work with autos. Steering box clearance is great. Excellent fit under the floor pans. What I don't know is if they work with factory AC.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old May 9th, 07, 07:19 PM
Don
I have Vintage air on my car with these headers, Your compressor is on left? I dont see what would get in the way that you can't refab to get them to work. I dont think the AC case would even get in way any more than a set of Hookers.
Don
TC # 349
Old May 9th, 07, 11:33 PM
Jerry
A/c compressor is on the right but a March Ultra front drive system is going in also (coming home present from the wife I just found out) so no worries on accessories clearance. My biggest issues will then be steering box, which everyone says is good, and clearing manual clutch linkage. I am putting a TKO in when I get home also.
  #11
Old May 10th, 07, 05:22 AM
RickD RickD is offline
You might want to verify the header port matches your cylinder heads. The tri-y's are 1 5/8" oval. In my case with Pro-Action 180's they were too small.
Thorley sent me a tracing of the header port. I can fax it to you if desired.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
  #12
Old May 10th, 07, 07:49 AM
Don
I did not have any clearance issues on steering box with Thorleys. I added ps.
Welcome Home
Don
TC # 349
  #13
Old May 10th, 07, 11:55 AM
Jerry
Well, I will be buying new AFR eliminator's so they should be fine. Sounds like the Thorleys will be it.
Thanks for all the input.
  #14
Old May 10th, 07, 12:02 PM
Don
I dont know what the exhaust port looks like on the cnc eliminators heads, but my thorleys fit perfect on my afr 195 heads. Using ultraseal black gaskets from Mr gasket # 5907. The have been there for last 3 years. Dead soft alum or copper, went to trash.
Don
TC # 349
  #15
Old May 10th, 07, 01:01 PM
ron498 ron498 is offline
Ron
When are the Doug's arriving?
RA
69 Nova
Single turbo alum 5.3 LS
9.45 @ 145.35 so far.....
2000 C5 Corvette Auto 10.99 @ 123.8 NA
I'll be back for you Jack, and I'll let the machine speak!
Team Camaro Tech > All Generations > Performance      Current Topic: Dougs Headers or Thorley's
Location
Location
First Name
Human Verification
Similar Threads
Dougs or Thorleys melav8r Engine 2 Apr 16th, 07 11:23 PM
Still problems deciding on which Headers for Fastburn Heads ... Dougs??? Tim_in_NC Performance 16 Oct 24th, 06 01:41 PM
Doug's headers are not perfect like everybody says! shockers69 Performance 9 Jul 16th, 06 10:22 PM
Doug Thorleys Tri Y's vs Hooker Headers CamFrk68 Engine 0 May 9th, 06 10:24 PM
Flowmaster kit fitting Doug's headers? shockers69 Performance 3 May 2nd, 06 05:54 PM
