firewall - Team Camaro Tech
Body Shop Paint & Body Forum
Old Mar 22nd, 02, 12:39 PM
RODKNOCKER RODKNOCKER is offline
Default
Anyone have any pictures of the top part of firewall from a side view I guess at one point someone bought a HEI dist. and was insuch a hurry to put it on used a ballpeen (sp) hammer to make some extra room for it.
The engine going back in will be a big block any pictures with a big block installed (side view) so that I could see dist to firewall clearance would be great also I'm smoothing out this firewall so factory appearance is not my top priority.
Thank You
Jeff
Old Mar 22nd, 02, 04:36 PM
TOMSTV TOMSTV is offline
TOM
Default
I'm using the Accell distributor,with the small cap on it.there is maybe an inch,or so between the it and the fire wall.The engine is a 454...
http://hobbystage.net/camaro/tomstv
Old Mar 22nd, 02, 06:21 PM
68BB427 68BB427 is offline
Default
Rodknocker,
Make sure you use the BB engine perches. They will move the engine 1" forward compared to the small block perches.
Old Mar 23rd, 02, 04:03 AM
Dan Smart Dan Smart is offline
Default
Check out the pics in my signature at the bottom. I had the same problem at the firewall with the previous owner & his hammer. He had a large HEI & needed room.
I took out the heater and pounded the hammer dent back to normal & finished it off for a cleaner look. The dist is a small Mallory with a Petronix module. As you can see, there's plenty of room.
Dan
http://hobbystage.net/camaro/dsmart
Old Mar 23rd, 02, 06:40 AM
Default
Thanks alot guys, great pics exactly what I was looking for I will also be using a small cap dist.
68BB427 Thanks for the reminder on the engine perches where did you buy yours from?
Jeff
Old Mar 23rd, 02, 07:26 AM
Default
Rodknocker, I got mine about 2 years ago. At that time, one side (I don't remember if it was the LH or RH side) was still available through GM. I got the other from Obsolete Chevrolet. I checked Rick's First Gen. catalog and found them on page 184. They are repro's. I didn't see what year your car was, 67-8 perches are the same for the two years, 69 are different that 67-8. Rick's shows they have them both for 67-8 and 69.
[This message has been edited by 68BB427 (edited 03-23-2002).]
