EFI in your modern Classic EFI conversions in FirstGen Camaros
Old May 9th, 07, 09:42 PM
Nomadkenn Nomadkenn is offline
Team Member
Ken
Unhappy Scanners for the350 RamJet
I have a EZ-Link Scanner with the OBD I(GM) & OBD II cable, just today Auto X Ray tells me they do NOT have a cable that connects to the RamJet with their EZ-Link. It turns out the MEFI-4 computer system was developed for the Marine Market, not the automotive market! The codeMate EFI code Reader, supplied with the engine, does allow me to set the base timing BUT I cannot do a complete scan like the OBD II system ( it does read out the 21 error codes). Other then dumping the EZ-Link scanner and going with the Rinda Technologies Inc. Scanners or the Diacom Marine software for my notebook PC, can anyone give me some help in scanning my RamJet 350 with Marine EFI?
Ken
Rides:
67 Camaro RS Vert
05 Corvette Vert
X-Rides
04 SSR
57 Nomad
Old May 9th, 07, 11:21 PM
davidpozzi davidpozzi is offline
David Pozzi
Default Re: Scanners for the350 RamJet
Ken,
Take a look here: http://www.sallee-chevrolet.com/Disc...3418/4500.html
Lots of Ram Jet owners on this forum.
I see MSD sells a repackaged MEFI-4 system and has full software to program it. But I don't know if it works on your system.
David
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
Old May 10th, 07, 05:49 PM
Team Member
Ken
David, your once again awesum! Thank you, thank you.
Rides:
67 Camaro RS Vert
05 Corvette Vert
X-Rides
04 SSR
57 Nomad
Old Jun 12th, 07, 06:19 PM
Team Member
Ken
Thumbs up Re: Scanners for the350 RamJet
Ken
I now believe the Scanner/Tuner of choice to be the OBD2AllInOne.com, located in Redondo Beach, CA. They have both a Scanner/Tuner AND just a Scanner, just be aware the MEFI may have to be erased and start tuning all over again with the scanner/tuner. To really find out what is going wrong with our RamJets we need to scan out MEFI's in real time when they are acting up.
Ken
Rides:
67 Camaro RS Vert
05 Corvette Vert
X-Rides
04 SSR
57 Nomad
Old Jun 13th, 07, 06:28 AM
Rich-Allen Rich-Allen is offline
The MSD MEFI4 unit is the same one Mark Stielow used on his LS7 build.
You can find a write up on it here: LINK
Rich
AFR Heads W/ Jesel valve train
http://www.fquick.com/Rich-Allen
67 RS / SS
http://eastbayerectors.com/camaro.html
Similar Threads
ramjet 502 CLEARANCE ISSUES mruders Body Shop 6 Dec 31st, 07 07:42 PM
502 Ramjet or ZZ502 for my 69 w/ Cowl-Ind. paul1969 Tech 2002 9 Dec 18th, 07 07:13 PM
Converting 502 Ramjet to Carb Jason4606 Engine 0 Apr 1st, 07 11:07 PM
350 RamJet engine Nomadkenn Engine 6 Oct 29th, 06 05:46 PM
Ramjet vs. 327 topend rebuild...final questions! stp327 Performance 9 Nov 23rd, 04 07:51 PM
