EFI in your modern Classic EFI conversions in FirstGen Camaros
Old May 11th, 07, 09:04 PM
kustomwerker kustomwerker is offline
mike
Default power potential
can you make any real power with an oem tbi setup or is it a waste of time???
sometimes you`re the windshield and sometimes you`re the bug...
Old May 12th, 07, 05:13 PM
Kokamo Kokamo is offline
Joe
Default Re: power potential
TBI has good potential for low end power. The engine is simply not designed for high RPM powerband where good power is usually made.
Altho, you can do some work with them and make them have good power for what it is. You can get different intakes, cams, and different heads, but you have to remember that you are still breathing thru a somewhat small 2 barrel throat.
Again, TBI is good for low end grunt, but not 600 RWH. You could prolly get 350 HP out of one, but by the time you got there, you would have spent the money it takes to buy an LT1 setup.
Hope this helps,
Joe
FYI.....I recently got 351 RWHP out of my 89 single cab 2wd Chevy pickup on the stock engine........only modification = 12 #'s of intercooled boost and a custom tune from www.lsracingchips.com
Old May 12th, 07, 06:57 PM
JimM JimM is offline
Jim
Nothing at all wrong with TBI. Holley makes a 670 cfm replacement 2bbl throttle body, or you could get one off a 454 truck in a boneyard. A 670 cfm TBI with an adapter on a performer rpm is all the induction a mild to medium 350 needs.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old May 13th, 07, 06:01 AM
mike
thanx guys...thats pretty much where i was at in my thoughts, but wanted to confirm...
Similar Threads
overlap, and stock idle L79Mike Performance 13 Jan 21st, 06 10:23 PM
need electrical help for keyswitch power bl1work Electrical & Wiring 3 Dec 29th, 05 06:12 PM
Correct power steering pump and pulley for 69 Z28 jlighthart Engine 0 Nov 15th, 04 03:52 AM
Rod Ratio and Power Potential Zachary Vonler Engine 12 Dec 26th, 03 06:27 AM
matching the power curve to gearing grumpyvette Engine 21 Jul 8th, 03 08:15 AM
