| Team Camaro Tech Current Topic: SBC and BBC distributor interchange | ||
| Engine General Engine Discussion. |
Will the older points type distributor (say 65 to 79) for small block motors interchange with the big block motors? Other than springs and weights are there any other differences?
Thanks for all inputs ahead of time. John Lighthart Charleston,SC |
| Sponsored Links | ||
Advertisement | ||
Nope different advance curve (especially in the vacuum can) otherwise interchangeable. I can not see going with a points distributor unless you need a numbers matching distributor, which it is not because they had different numbers. There are people that make HEI's that look like old school distributors and even those that look like a magneto.
Larger Dave |
Don TC # 349 Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E http://s102.photobucket.com/albums/m...t=115_1577.jpg |
| Sponsored Links | |
Advertisement | |
Similar Threads
| SBC to BBC in a 68 | Pauly | Engine | 6 | Feb 17th, 07 06:09 AM |
| changing a sbc ac car to bbc ac car | Angie W | Heating & Cooling | 11 | Jan 18th, 07 06:06 PM |
| 67 camaro sbc to bbc | dburing78 | Heating & Cooling | 5 | Aug 30th, 06 12:40 AM |
| IS bbc smog set up same as SBC...need help | 69RS/SS396ragtop | Restoration Corner | 11 | Dec 28th, 05 03:09 AM |
| bbc tunnel ram top same as SBC tunnel ram top? | 67stang | Engine | 1 | Nov 22nd, 05 06:28 PM |
