Wont stop turning over - Team Camaro Tech
Old May 16th, 07, 08:37 PM
Bug Bug is offline
Alyssa
Default Wont stop turning over
I have my engine all wired up but when I went to try and start it the engine would turn over and when I turned the key off it kept turning over. So I had to pull off a battery cable to get it to stop. (I have the purple wire closest to the block and the + battery cable connected but nothing else cuz i have a distributer w/o a coil) is that correct? Anyways i took the starter off the block hooked it up the same way i described and grounded it turned the key and it turned off when it was supposed to. Anybody know whats goin on?
Thanks alot
Old May 16th, 07, 08:52 PM
rod67ss rod67ss is offline
Tech Team
Rod
Default Re: Wont stop turning over
Sometime you need to shim the starter. If the clearance is too tight the selenoid can't retract when you let off the key. As long as it's engaged it'll draw current just like you've got the key turned.
Old May 17th, 07, 09:44 PM
spideynut spideynut is offline
Brad
Wheres your yellow wire?
Most recent 01/01/10
http://i610.photobucket.com/albums/t...HOTRODS015.jpg
Old May 18th, 07, 06:30 AM
Bug Bug is offline
Alyssa
Does that still need to be connected even though my distributer does not have a coil?
Old May 19th, 07, 05:48 PM
JohnZ JohnZ is offline
Team Member
John
What kind of distributor do you have that doesn't need a coil?
JohnZ
CRG
'69 Z/28 Fathom Green
Similar Threads
88 Camaro Engine shuts off at stop signs and when turning. doug2060 Troubleshooting 3 May 3rd, 07 01:31 PM
69 rear turning lights & headlights? Frost Green 69 Electrical & Wiring 1 Oct 10th, 05 06:55 AM
USING A DEGREE WHEEL TO DETERMINE CAM mark67ss Performance 9 Feb 11th, 05 01:48 PM
Turning car off while at a stop in drive? 4U 2 NV Engine 3 Sep 10th, 04 01:56 PM
Using a piston stop to time my motor 67killerb Engine 2 May 13th, 03 03:44 PM
