| Team Camaro Tech Current Topic: 68 camaro | ||
| Pro Touring Todays performance with classic style |
I just bought my first 68 and was looking at the new crate motors,the car i bought has no motor tranny or radiator,they sell a turn key motor but it has a long shaft water pump,has anybody installed one of these and just installed an after market radiator with electric fan.Any help would be much appriciated,Thanks Gbatey
i did a crate motor from engine factory 350/430hp loaded inside , hooked it up to tko 600 5 speed tranny and used a ron davis radiator with twin spal fans. there are less expensive alternatives too.
68 ss clone sbc350 tko600 chassisworks , 69 LSX454 bbc (in progress jakes), 70 rs 454 mp500efi |
I bought a turn-key 383.. added a 700R4, long water pump, and alum radiator.
I decided against the electric fan and installed a Flex-a-lite 7-blade fan. My '68 runs and cools fantastic.. I'm very happy.
www.ColoradoCamaro.com Last edited by Ghostbuster; May 18th, 07 at 10:19 PM. |
Did you have any trouble with the fuel pump tite against the upper control arm,Thanks Gene
Yes, fuel pump was really tight against the cross member-no matter the clocking. I believe I ended up using a carter pump.
"Are you pickin up what I'm puttin down?" MY garage- http://www.fquick.com/ertoys Last edited by ertoys; May 31st, 07 at 11:08 AM. Reason: Additional info |
See my signature for what I went with.
Used a short water pump and electric fan. Used a Holley Blue Electric fuel pump. Tim
Meanchicken 68 SS ZZ502; TKO-600; 3:73 Moser 12-bolt w/Detroit TruTrak; SSBC Force 10 4 wheel power disks;QA1 Coil Overs; Global West Tubulars;GNX Quick Ratio 12:1 PS; Hotchkis Front Sway Bar 87 Buick Grand National |
68 502/502 with kiesler 5 speed. dual electrice fans.373 posi rear with four wheel disc. brakes. go fast but stay cool.
reddog68prostreet |
Similar Threads
| 68 Smokey Yunich Camaro Look? | teSSa | Bench Racing | 6 | May 31st, 06 08:55 AM |
| MAILBAG: Readers give reactions on Camaro | OverAnxious | Fifth Generation | 0 | May 18th, 06 08:07 AM |
| 68 camaro proportioning valve | 68Camaro77 | Camaro Tech | 1 | Apr 16th, 06 12:26 PM |
| DIY Network 1968 Camaro Restoration Show | Brentmc | Bench Racing | 2 | Mar 14th, 06 10:41 AM |
| 68 camaro new engine | bmattie | Bench Racing | 5 | Mar 9th, 06 05:05 PM |
