EFI in your modern Classic EFI conversions in FirstGen Camaros
Old May 23rd, 07, 10:07 AM
paulm paulm is offline
Paul
Default New Intake!!
He, He....now that I have the engine running great with the LT1 intake I think that I'll switch to a new one (always gotta have a project going you know). Ha, and I sold some tools locally (thank you Craigslist) so I have money to burn!!!
I think that I'm going to switch to a Holley Stealth Ram. It looks really gawdy since it seems to have been based on the old dual quad intake ( http://www.holley.com/7542P.asp ). Can't beat the "cool" factor and it's really not all that expensive ($309 for the unpolished). All of my stuff will just swap over from the LT1 intake, so.....
Anyone have a reason that I shouldn't use this intake?
My 67 HSR Intaked RS Coupe
Best of 1.56 - 11.69@112.95
Old May 25th, 07, 01:54 PM
JimM JimM is offline
Jim
Default Re: New Intake!!
nope...
but is it really any better that the LT1?
Will it fit under your hood?
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old May 25th, 07, 02:14 PM
camcojb camcojb is online now
Jody
Originally Posted by JimM View Post
nope...
It will clear the stock cowl hood on a small block. Probably won't have the top end of the LT1 intake, but better low end. Seems to be where the Holley shines, low/mid range grunt, but runs out of air for high rpm useage.
Jody
new updated website!
64 Chevelle twin turbo LS2
Old May 25th, 07, 05:34 PM
Paul
nope...
but is it really any better than the LT1?
I dunno, but I think that the "cool factor" goes up!
It also will clean up the coolant routing and give me a little "cleaner" look. It's kind of tight back by the dizzy with the coolant hoses and fuel lines. Makes it harder to work on, that's probably what I'm most interested in fixing.
Jody
Well I run a GM 962 cam (224/224 .450/.460 114) in my 383, so it doesn't rev much past 5k something anyway.
We'll see how it runs with the Holley intake. I didn't really build the car with a certain HP or ET in mine. Just a fun car to cruise around in. In the 69 ragtop with the same engine/tranny my best run was 13.2 at 104-5 (I think, after a quick review of my slips), so I figure maybe I can get 12's in the coupe and that's good enough for me.
Old May 25th, 07, 05:38 PM
Jody
should be a great match for that rpm range.
Jody
Similar Threads
just got my new intake in for the BBC...i want to cry 67stang Engine 11 Nov 7th, 05 08:05 PM
Garage find... '81 Z28 aluminum intake HwyStarJoe Engine 16 Feb 15th, 05 09:19 AM
pro action (pro topline) intake gasket solution 68rs406 Performance 4 Aug 16th, 04 04:28 PM
Intake Gasket Woes rojo Engine 5 Sep 22nd, 03 04:11 AM
Help with intake leak causing oil smoke 68SSConvt Troubleshooting 3 Jun 8th, 02 04:26 AM
