| Team Camaro Tech Current Topic: Belt Setup | ||
| Engine General Engine Discussion. |
Hey,
I am 95% through my Vintage Air A/C install (new Gen IV unit), and i have a question about how best to route my belts. I have a passenger side alternator and driver side p/s pump and a/c compressor. My crank pulley has 2 grooves as does the a/c compressor pulley. I was thinking of routing one belt between the crank , water pump and alternator and the other belt from teh crank to the p/s pump to the a/c compressor. Looks like nothing will hit the belts in this cofiguration. Is this an okay way to route the belts? Is there a preferred way?
69 Camaro - 350 .060 over, TH350, Stock rear end |
| Sponsored Links | ||
Advertisement | ||
I was about to post a similar question. My 69 has a marine engine and I think it may have the pulley setup off it as well. Scalise- can you send me a few pics of how you routed everything? My email- grsdup1@aol.com. What year/motor are you working with? Scott
69 RS LS1/T56 -now on the road 68 Firebird vert future project 67 LS1/A4 SOLD |
Any ideas/thoughts?
z06vette i I'll try and get some pics tonight, although I don't have a belt around the A/C comperssor yet. That's why I was posting. :-)
When I installed this sysytem on my 68 big block with the altenator on the passenger side. There was no way to have 2 belts to the A/C compressor. I called vintage air to ask what to do an they said you only need one belt on the compressor. Have installed and been useing the system for month or so and it works great with only one belt.
There are no problems only solutions 68 Camaro, RS/SS, ZZ502, Retrotek Fuel Injection, 4 Speed. 2010 RS/2SS Black, 6 speed trans |
So how do you have your belts routed then? Are you using Power Steering? I assume you are using only 2 belts total?
scalise, the problem I see with using the same belt for A/C and PS is that the belt will be overloaded and the accessories will lose belt contact area and thusly cause them to slip when under a high load. You can visualize the effect. Picture in your minds eye how much belt will be in contact with the PS pulley if it's just driving the pulley. Then see how much is in contact with the PS pulley if it has to go to the A/C clutch too.
I don't think you'll be happy with the resultant squealing. I'd try to score a 3 grove drive pulley.
One owner 69 Camaro,(yep, bought it new )RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers. TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60' All with 1960's stuff. (except tires and converter) + MT Super Scavenger headers. 1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too. ![]() http://epitomesrebuild.com/ |
| Sponsored Links | |
Advertisement | |
Similar Threads
| seat belt warning switch | 69chevyguy | Electrical & Wiring | 1 | Jul 12th, 06 05:42 PM |
| 68 Z-28 Belt setup | 68 RS 302 | Engine | 2 | Dec 14th, 05 03:03 AM |
| Alternator Belt Squeal | Barry H | Tech 2000 | 12 | Jul 25th, 01 06:08 AM |
| Power Steering / Belt Alignment Problem | kgaffney | Tech 2000 | 17 | Jul 9th, 01 04:36 PM |
| Alternator belt screach on 69camaro | joe clance | Tech 2000 | 5 | Mar 25th, 01 05:54 AM |
