Paint or powdercoat pulleys & alt brackets? - Team Camaro Tech
Thread Tools Display Modes
Old May 24th, 07, 10:50 AM
Mike_M's Avatar
Mike_M Mike_M is offline
Mike
Default Paint or powdercoat pulleys & alt brackets?
Just wondering if it's better to paint or powdercoat the pulleys, alternator brackets, and factory-type 5 blade clutch fan? I imagine the powdercoat would provide better corrosion resistance, but will it hold up to the temperatures? Thanks.
Old May 24th, 07, 10:55 AM
dnult dnult is offline
Default Re: Paint or powdercoat pulleys & alt brackets?
Powder will do fine and look the best IMHO. I'd mask off the belt surfaces though. Not sure what power coat would do with a belt running against it. I guess you could power coat the brackets and paint the pulleys - it would be easier to mask them that way. You may want to run a pigtail ground from the alternator to the block though. Powder coatings are prone to leaving you with bad grounds, and you'd hate to have to mess up your coating to get a good ground.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old May 24th, 07, 01:01 PM
Mike_M's Avatar
Mike
Thanks - I hadn't considered the grounding issue, that's a very good point. Maybe in some ways it would be much easier just to paint the brackets, although I do like the idea of the powdercoat.
Old May 24th, 07, 01:28 PM
satz28's Avatar
satz28 satz28 is offline
Rob
I powder coated everthing I could on my 69Z. I've had 0 problems with grounding issues or belt problems after 5 years. Once you do powder, you will never go back to painted parts.
Rob
Sold 6-1-2014 after owning the car for 18+ years
69 Z-28 X-77 HO * DZ Put away * M20 * 4.10
406 CI * CC XR274R 236/242@.050 564/570 110 LSA/106 ICL * Brodix IK 200
475 HP, 495# tor
Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH
Old May 24th, 07, 02:04 PM
DOUG G DOUG G is offline
Used to work for a powder coating Mfg. and brought all my parts in the back door All were done in a 30% gloss black (almost flat). It's been over 7 years and they look like they were done yesterday
68 Camaro~LSx
Best to Date....and tuning
1.546 60'
7.132 @ 94.43 660'
11.327 @ 116.79.
RedЯum <-Pics
https://youtu.be/Of8WVNYhR1g <~More here
Old May 24th, 07, 02:32 PM
SooperDave SooperDave is offline
Dave
once I tried powdercoating some brackets and pulleys a few years ago I definitely shy away from painting. that being said, the stuff is not bulletproof...the durability is slightly overstated in my op. the coating will come off when you torque down bolts. but just not nearly as bad as paint. i just got a set of M/T valve covers done and they look awesome...I was stoked!!!
68 Z/28, grotto blue, protect-o-plate
67 plain jane survivor, deep water blue, protect-o-plate
Old May 24th, 07, 04:33 PM
Joe Harrison's Avatar
Joe Harrison Joe Harrison is offline
67 Camaros Rock
Talking Re: Paint or powdercoat pulleys & alt brackets?
Clear POWDER on my intake, Chrome aluminum on my pullys and brackets, high temp gray powder on the headers, control arms are powder, fan is powder.
Frame is PAINT ultra black with 3 or 4 coats of clear.
"If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn.......
Then, you have enough horsepower."
-Mark Donahue
My 67 Camaro Time Line http://www.camaros.net/forums/showthread.php?t=211805
Old May 25th, 07, 07:31 AM
Mike_M's Avatar
Mike
Thanks - looks like I'll be powdercoating them, then! Those pics look awesome, Joe
Old May 25th, 07, 04:19 PM
67 Camaros Rock
Thanks!!
More to come soon...........just put it under the 67. It's been painted......................finally!!!!!
Looks good, just have to save up for valve cover adaptors and new GM valve covers.
Joe
-Mark Donahue
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Paint or powdercoat pulleys & alt brackets?
Location
Location
First Name
Human Verification
Similar Threads
tail panel/trunk brackets skreese Body Shop 4 Feb 4th, 03 05:07 PM
HOTRODSRJ - ConceptOne Pulleys and Brackets gr868 Troubleshooting 3 Jun 18th, 02 10:57 AM
How much did your paint job cost? sik68 Body Shop 6 Dec 28th, 01 12:20 PM
Brackets & Pulleys 69BBSS Tech 2000 3 Dec 5th, 00 11:07 AM
Pulleys and Brackets CA420 Tech 2000 2 Oct 24th, 00 01:06 PM
