mono leaf to multi leaf conversion - Team Camaro Tech
Camaro Tech General Tech Area
Old May 25th, 07, 08:42 PM
g40dog1 g40dog1 is offline
genaro
Question mono leaf to multi leaf conversion
ladies & gents, i could use a little info on this swap i'm unshure of the parts needed.swapping out my mono leafs to multi (dse 3" drop ) all info would be greatly apperciated. thanks g.m.
Old May 26th, 07, 06:09 AM
67pat 67pat is offline
Pat
Default Re: mono leaf to multi leaf conversion
I'm in the middle of a 1 1/2 in hotchkis rear conversion...so similar but not as radical with the 3 in....wow thats gonna be Looow! I dont know what your kit includes my conversion has been a challenge and i dont want to bore you with elementary stuff you may know...what exactly are you looking for, problems,stuff to look for,things you have to come up with...or do you want me to give you the whole explanation...I dont mind if you do
Old May 26th, 07, 09:00 AM
genaro
i just have the springs only, i need a parts list for small parts needed like perches ,correct lenght u bolts etc... thanks g.m.
Old May 26th, 07, 09:10 AM
Pat
I can give you the u-bolt size which is plenty long for what ever spring you got...you have to drill the axle plate and shock connector plate out to 5/8ths to allow for the u-bolt...the perches i have were about 1/2 inch thick polyurethane that under 45# torque are now about 1/4 thick. The shackles are 1/4 x 5-1/4 inch.I need to run out to my shop and I'll give you the shackle bolt size and u-bolt size...so I'll post that in a minute.
Old May 26th, 07, 09:16 AM
Pat
The u-bolts are 8-1/4 inches long from outside of the top to bottom...it is 4-1/4 across the -u- outside and it is 1/2 in bolt size....might have a problem here ...its grade 8. The shackle bolts are 1/2 x 5-1/4...with a lock nut...also grade 8...let me know if you need something else.
Similar Threads
Split mono leaf verses multi leaf Liveinaz Brakes, Suspension & Steering 1 Dec 9th, 06 10:59 AM
Mono Leaf to Multi Leaf Conversion Eke Transmission & Driveline 7 Aug 23rd, 06 05:34 PM
Mono to Multi Leaf Conversion ? Camaro Dave Brakes, Suspension & Steering 14 Jul 5th, 06 06:47 PM
mono to multi leaf conversion drilling a center hole coffeeguy Brakes, Suspension & Steering 13 Mar 2nd, 06 09:04 PM
mono leaf too multi leaf conversion pinetop1 Brakes, Suspension & Steering 6 Oct 19th, 05 07:36 AM
