Exhaust w/ X-pipe Question - Team Camaro Tech
Old May 28th, 07, 08:13 PM
.gearhead.'s Avatar
.gearhead. .gearhead. is offline
Jim
Default Exhaust w/ X-pipe Question
I'm at the point in my project where it's time to figure out my exhaust situation. I run a 408 sbc with Hedman 1-3/4" coated headers. I just purchased a set of 3" Borla XR-1's (12" body w/ center inlet/outlet). I plan to run a 3" exhaust with an X-pipe and turndowns at the mufflers. I eventually plan on a full welded system, but the engine/header combo is only temporary, until a Dart smallblock is finished, so I'd like to plan for a re-usable system.
Does anyone have a similar combination? If so, did you buy a kit, or have the exhaust fabbed? I'm considering a pre-bent pipe kit, but there are a ton and I'm a little confused... It would be nice to bolt one on until I change over. Got any recommendations?
Also, are there any kits available that dump the exhaust to the side in front of the rear tires?
Thanks.
Jim
1968 Camaro
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
Old May 28th, 07, 09:54 PM
bills68camaro bills68camaro is offline
bill
Default Re: Exhaust w/ X-pipe Question
Jim, I have a similar combo & this is what I did. I run 1-7/8" x 3-1/2" super comps & i called DR Gas for the x-pipe system & spintech mufflers. I ended up per their recomendation, with a 3-1/2" before the x to 3" after the x system (all in pieces) & was able to fully install it in an afternoon. I dumped mine right after the axle but you could easily dump out the side in front of the tires just as easily. I tacked the whole system together in the car then pulled it down & fully welded it. It looks & sounds awesome! You could clamp the whole thing together if you want but if you are running the same headers with the next motor, I guess you could weld it all together now? I would not hesitate to buy again from DR Gas. Bill.
68 camaro, 434 sbc, th400, 12 bolt.
Similar Threads
exhaust question. bb489 Performance 7 Jul 2nd, 06 11:13 PM
Exhaust question... jsouthco68camaro Engine 5 Mar 28th, 05 06:14 PM
What size exhaust/ x pipe for my combo? Luke805 Performance 7 Jan 24th, 05 07:40 AM
Exhaust crossover pipe 69 Rat Performance 7 Nov 23rd, 02 10:53 AM
exhaust question 92 RS Tech 2000 1 May 20th, 01 10:15 AM
