what's it called and where to get it - Team Camaro Tech
Body Shop Paint & Body Forum
Old Aug 27th, 03, 06:01 AM
Oncea3Fan Oncea3Fan is offline
Post
looking for the sheet metal piece that I believe is connected to the body metal between the rear window and truck deck.
this would be the portion that runs under the window and inside the car down to the package tray
also the corner trim screws in to this piece.
what's it called where can I get it ???
I see rick's has it in a one piece connected to the piece between truck and window but I don't need all that.
if some has a used one I could refubish it.
thanks!
Will
"Drive it like you stole it"
http://img317.imageshack.us/img317/9421/67sig4ev.jpg
2000 SS camaro daily driver(wifes)
GoTeamsGo Sports Forum
Old Aug 27th, 03, 07:15 AM
MangeMD MangeMD is offline
Angry
You mean the 'filler panel'?
Look at http://www.goodmarkindustries.com/gr...20-710-671.jpg
The new tooling version of the filler panel extends down to the package tray. The old one does not.
1967 Coupe: 406 SBC, Thorley headers, Muncie, Hotchkis suspension, Centerline Matrix 17" wheels with Nitto 555's, Baer brakes, 12 bolt 3.73 posi, RS conversion, Vintage Air, PPG Hot Red.
http://webpages.charter.net/cremeans
Old Aug 27th, 03, 07:45 AM
Post
yes ,but I only need the interior filler panel as my paint is good and I don't wish to replace the whole panel.
Old Aug 27th, 03, 11:40 AM
Arrow
Umm...I haven't seen that offered before. You could but the interior part off this one, but the welding will kill your paint.
Old Aug 27th, 03, 08:10 PM
VINTAGE CAMARO VINTAGE CAMARO is offline
Angry
Just for informations sake, the panel is called the Tulip panel. Until 3 months ago the interior part was only available used, but Goodmark reproduced the panel in its entirity. Unfortunately you would have to purchase the entire panel, which I stock, at $98. You should be able to remove the rear window and using the new body adhesives, glue the interior piece with the window channel in. This would save you the welding and with some seam sealer and new window urethane sealer, you should be uptown and rolling. [img]graemlins/beers.gif[/img]
Old Aug 27th, 03, 11:37 PM
Toby Keen Toby Keen is offline
Post
Not trying to be argumentative but I always heard of the "Tulip Panel" as the OUTER panel between the deck lid and the rear window. In the body trade it's known as an "Upper Deck Panel". Unless I'm mistaken, he's looking for the interior panel that your shoulder would be against if you were sitting in the back seat. The only way I know of getting one of those is from a donor car. The only other piece that comes to mind would be the inner sail panel which would also come from a donor car. Just trying to help.
Old Aug 28th, 03, 01:44 AM
Post
the piece is between the rear of the package tray and the rear window in the center.
I was hoping not to need to buy and cut a full panel,but I gotta do what I gotta do.
thanks!
Old Aug 28th, 03, 02:00 AM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Post
Hey Will,
I've had to buy whole panels and chop them up. It sucks but sometimes it's your only choice. I need only that area of the back window also but I decided not to at this time.
Why don't you carefully remove the portion that you want and then offer the remainder to someone that needs the outside portion? Then it won't go to waste.
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Aug 28th, 03, 07:17 AM
Post
sounds like a good Idea!
